Gaskets are typically replaced whenever their mating surfaces are separated. O-rings, in relatively easy to access locations (like carbs), can be reliably reused as long as they're still in good condition. If your carb o-rings are old enough that they need to be kept in gas during carb work to keep them from hardening and cracking, then it's time for new o-rings.
