Author Topic: Missing parts to a CB500 Petcock (dual out nipples.)  (Read 3197 times)
Offline papp101
« on: March 19, 2009, 12:01:23 PM »
Hey team,
It seems that the PO YANKED out the gas lines from the petcock and it took the nipples with it. I don't have those hoses unfortunately.
Here's my petcock and the holes.
Is there something I could use to replace the cracked inlet hose?
Is there somewhere out there people have found replacement nipples? What else could I use?
Thanks!
Re: Missing parts to a CB500 Petcock (dual out nipples.)
« Reply #1 on: March 19, 2009, 10:26:23 PM »
Er
No
No
Dont think there is
I think a new petcock is called for
Offline vames
« Reply #2 on: March 20, 2009, 04:31:13 AM »
There's gotta be something you can do. A good plumbing or aquarium store would probably have miniture fittings with barbs on one end, threads on the other. Maybe you could drill the hole out a bit, tap it, and screw into the housing. Or just drill and friction-press in a piece of copper tubing.
Offline papp101
« Reply #3 on: March 20, 2009, 05:34:06 AM »
I know, I'm feeling something like a plumbing store or that little display wall at home depot for the barbed fittings, and hopefully just tap/thread them in. Come to think of it they have some brass hoses as well.
2 kweztions.
Is brass ok to put in the tank?
Do you think a threaded nipple will cause any problems now that there wouldn't be anything shuved far up the petcock?
Offline tomkimberly
« Reply #4 on: March 20, 2009, 06:36:27 AM »
You can "McGiver" it but it will much easier to just purchase a new one from either Honda or Z1 Enterprises.
Tom
Offline JS550
  • the artist formerly known as
  • IAFF local 1307
« Reply #5 on: March 20, 2009, 06:52:43 AM »
That sucks! I was looking for another petcock a while back & a guy on here sent some picks of one he used that he put together with parts from Lowes or HomeDepot. If you dont want to spend the coin on a fresh one that might work.
If you're worried about how many calories are in beer, is losing weight really your biggest problem?
Offline papp101
« Reply #6 on: March 20, 2009, 09:26:13 AM »
Maybe these?
http://www.fittingsandadapters.com/hosbartomalo1.html
Or just a brass one:
http://www.fittingsandadapters.com/maljichosbar.html
The only thing I worry about is having enough wall strength left after i tap them in, as most of them are a little large on the thread size. I'll have to take it to home depot and check it out.
thanks for the heads up guys, I'll post pics when I'm done.e
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #7 on: March 20, 2009, 12:29:28 PM »
That fuel tap (pet cock ??) is dead anyway so you may as well try one of these.
Let us know what happens.
Best case - great new item for "Tricks & Tips"
Worst case - buy a new one!
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
Offline papp101
« Reply #8 on: March 20, 2009, 10:08:52 PM »
Right on! I'll be stopping by home depot tomorrow, I don't see any reason we can't resurrect it! I consider it my own type of customizing, you know?
I'm denting and scratching my tank tonight! (hopefully. Or I might do carbs.) Got off work early and the GF is already asleep, so it's free time.
Offline papp101
« Reply #9 on: March 24, 2009, 12:10:36 AM »
Done and done!
Super easy, just go by the pix.
Offline cb350twin
    • http://mail.google.com/a/sohc4.net/
« Reply #10 on: March 24, 2009, 06:33:39 PM »
Awesome now you got to see if it leaks or not.   ;D
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
