Hello, .. How about this? I picked up a low mileage CB 650, that can be started only by jumping across the solenoid. The bike does run, a slight click is heard when pressing the starter button, .. but, no turning. I tried to "repair" the original solenoid, but noo way .. So, what I have now, is a crap solenoid installed necessary to permit any electrical function. I just have to jump across the solenoid terminal. And away I can go ..
OK, .. I get a price for a new one of $95 at the Honda shop, and I decide to go with an aftermarket one instead advertised as "New Honda CB650 CB700 650 700 Nighthawk Starter Relay". First, because the plug-in connection is placed on the opposite side (new) from the original, I hooked it up wrong, (battery to motor, and the other way around) with the obvious non-result, .. finding my error, I hooked it up the right way, hook the battery again, .. and the fuse blows, .. consistently, .. I thought I've ruined the solenoid, .. reordered another, hooking it up right this time, with the same results, blown fuse, immediately. The connector plug can only be put in, one way, as alot of you probably know.
hmm, .. mind you, all the electrics work fine. The bike is running fairly well. I checked the wiring diagram and found the wire from the starter button to the solenoid, .. and checked it with a multimeter, .. and there's no current that goes through until the button is pressed. If the ignition is on, and in neutral, the neutral light and oil pressure light get a little brighter, when I press the starter button. (No fuse blowing, here)
Now, I suppose there might be something wrong with this aftermarket solenoid's wiring configuration of the connector plug, .. Although, a person would think they would have had complaints, by now.. I have found another used solenoid on Ebay, .. (the money order seems to be hung up, between here and Canada, somewhere) .. and I'm very curious to see if that makes the difference, .. or if the learned readers here might know of something else that I have to do, to fix this problem? .. The answer is worth several beers, to me .. haha ..
Thanks for your time ..
Ken
