Author Topic: cb750 F2-F3 question  (Read 1296 times)
Offline hapakev
  • Your Standard
« on: March 21, 2009, 12:55:01 PM »
whats the pump mounted under my battery for?  looks like the disconnected lines maybe hook up to the gas tank?  any help appreciated.
Smoking Jack
1978 CB750F(ish)
Offline MrZxp
Re: cb750 F2-F3 question
« Reply #1 on: March 21, 2009, 12:59:21 PM »
Don't know that there is a pump mounted under there... in fact I'd say that there isn't!  :o
Probably you are seeing the components related to this, it is mounted under the battery:
Cheers, Phil
09 Boulevard M90
SOHC4 Member #3336
Offline hapakev
  • Your Standard
« Reply #2 on: March 21, 2009, 02:57:01 PM »
That looks to be it.  Thanks for the knowlege
Smoking Jack
1978 CB750F(ish)
Offline eurban
« Reply #3 on: March 21, 2009, 03:34:46 PM »
IF you like, download this factory manual and read . . .
http://www.mediafire.com/?5ttzdg9yyuz
Offline hapakev
  • Your Standard
« Reply #4 on: March 21, 2009, 03:53:12 PM »
You are a life saver.  thanks man.
Smoking Jack
1978 CB750F(ish)
