Author Topic: Any special goop recommended for installing exhaust?  (Read 1418 times)
Offline grumpy
  • ..... '73 750K3 .....
« on: March 25, 2009, 05:42:21 PM »
Is there any spacial sealant, balm, or potion needed on the exhaust flange / pipe junction when installing pipes on a 750 K3?
Like RTV or anti-seize...
Or is it just straight up install the gasket > flange > pipe > clamp > tighten ?
« Last Edit: March 25, 2009, 05:54:48 PM by grumpy »
Offline mystic_1
  • 1970 CB750K
Re: Any special goop recommended for installing exhaust?
« Reply #1 on: March 25, 2009, 05:59:27 PM »
No goo!  Just fresh exhaust gaskets, make sure everything's square before cinching down the fasteners, and don't loosen once you've tightened.
mystic_1
PS you got the old gaskets out, yes?  Just checking.
- John Augustus Shedd
Offline grumpy
« Reply #2 on: March 25, 2009, 06:05:42 PM »
No goo!
No goo. Got it.
Yep, old gaskets are in a pile on the floor.
Thanks!!
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: March 25, 2009, 06:08:01 PM »
Support the pipes at the rear end, but don't fasten them to their hangers, so that the flanges are square against the ports at the front.  Tighten front, then mount the rear hangers.
mystic_1
Offline grumpy
« Reply #4 on: March 25, 2009, 07:01:38 PM »
The PO had some putty jammed in around where the pipe abuts the outside of the flange...
Hard to get it off completely  >:(
I'm anticipating an exhaust leak  >:( >:(
Offline smpls70
« Reply #5 on: March 25, 2009, 07:28:05 PM »
gasket??when I swicthed out my pipes on my 750 there were no gaskets,are these absolutely imperative?will not having them effect the performance of the bike?
ROTHNOTHAGAR !
Offline Gordon
  • 750K1, 550K2
« Reply #6 on: March 25, 2009, 07:36:19 PM »
They're in there, you just didn't see them because they're squashed flat, covered with soot, and blend in with the exhaust ports.  If they weren't there, you'd know by the sound and you could feel the exhaust pulse leaking out around the flanges.  You probably could use a new set, though.
Offline smpls70
« Reply #7 on: March 25, 2009, 07:42:52 PM »
ahh,I will will have to investigate.........thanks
ROTHNOTHAGAR !
