Mankind is NOT a rational animal. Mankind is a rationalizing animal.
I have bikes over thirty years old that still use the fuel tap filter that has never been cleaned. They still don't need it either.
I also don't have children (of any age) adding crud to the fuel supply either.
The older Hondas I have with the sediment bowl get checked/ cleaned whenever I get around to it.
Any of the tanks I've encountered than had problems with any filter, also had tank rust issues, that a monthly (or hourly) in-line filter change will never cure.
I've never needed to bend down over the tank while riding to see clean fuel moving through a fuel line, nor do I ever expect to. (Such a practice is rightfully self limiting.)
I can open the tank's gas cap and look inside to see if there is gas (almost always while parked).
If I see enough crud in there to effect filter flow, I'm removing the tank and turning it upside down to get that sh!t out of there!
If one wants to put band aids on a broken arm, I'm sure that if one thinks about it long enough, one will be able to justify it's use. Let's see...
1 - It's cheaper than a cast.
2 - It's easy to lift so one can check if the wound is healing or if gangrene is setting in.
3 - They are available at any drug store and one can find a band aid in most inexpensive emergency kits. (Try finding a real cast in there!)
4 - It helps keeps the dirt out of the wound where the bone pokes out of the skin.
5 - it's far more flexible than a cast, and if one needs rigidity, an ordinary twig can substitute, just use more bandaids to hold the twig on, further, branch bark can add natural healing enzymes to speed healing. Disposal is natural and good for the environment. (The twig, that is.)
6 - If God had wanted us to use casts, he/she would have provided them in nature.
7 - One can write things on band aids with a sharpie, just like with casts.
8 - Band aids come in such pretty colors, and some are even shiny, (oooooo, shiny!!!)
Yep, easy to see that band aids are as vastly useful as in-line fuel filters.
Hey, if you want to use an additional in line filter, go ahead (for whatever reason you wish to create). Just stop trying to convince the unwary about their false importance over what was provided by the original manufacturer.
They are NOT there to clean the fuel. The person filling the tank is supposed to ensure that. They are there to keep neglect of the fuel system from requiring the overhaul of the carbs. And, that is true if using the original filters or ones that were added by the neglectful owner.
Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy? Can I have one, daddy?
Oh ALRIGHT!!!!
What a silly waste of time this is .... So, what's the best oil should we use to pre-lube those in-line filters?
