Author Topic: stripped carb hole  (Read 1723 times)
Offline 73hutch
stripped carb hole
« on: March 28, 2009, 02:43:40 PM »
when i rebuilt this set of carbs three years ago, i managed to strip the hole that the carb bowl screws into. i was told by the guy at the shop that i buy parts from to get a self tapping screw and that should work. i ran with it for a while but it always leaked a little. i haven't used those carbs in a year of so and i'm getting ready to put them on another bike. i unscrewed the bowls the other day and now the self tapping screws won't hold it at all. my question is: is there anything i put in the hole (jb weld?) to create a better hole to screw into? i do have a set of carbs to use for parts. so if nothing else, i can replace the whole carb. (i guessing that what you folks are going suggest i do).
78-550k
72-cb100
63 c100
75 xl350
84 gl1200
Offline punch455
Re: stripped carb hole
« Reply #1 on: March 28, 2009, 02:50:52 PM »
If there is enough space around the hole, maybe just tap new threads.  Do it once and it will hold just as long as original.  Take one of the original screws to a hardware store, find out what size it is, and buy a tap the next size up, and a new screw to fit the new threads. Your only other real option is to get a longer machine screw and put a nut on the top and tighten the two together.
'78 CB750F
Daytona Bars
Bar-end Mirrors
Custom Rearsets
Offline Soos
« Reply #2 on: March 28, 2009, 02:55:59 PM »
Have you looked into having a helicoil put in there?
Not sure there is enough meat for a timesert though.(is that the right name?)
Or (hate to mention this) tap it bigger.... might have to enlarge the hole in the float bowl though. Might weaken the float bowl, or the head might be to big, not allowing you to tighten it all the way.... But it's an option I guess.
I dunno about JB weld holding threads... i've always tried to shy away from that stuff unless I am seriously pinched for time or money.
Not saying it will not work... just very little experience with it.
I'm guessing you either have a '79/80 cb650, or a '77/78 cb750??
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline Soos
« Reply #3 on: March 28, 2009, 02:57:01 PM »
Thats something I hadn't thought of, not too bad an idea as the hole is on the outside carb at least.
l8r
-=≡ Soos ≡=-
Offline bender01
« Reply #4 on: March 28, 2009, 02:59:55 PM »
try this .
 http://forums.sohc4.net/index.php?topic=37129.0
  Worked great for me.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline 73hutch
« Reply #5 on: March 28, 2009, 04:13:11 PM »
i'm liking this idea. going to look and see it will work. thanks for all the advice! BTW it's a 78 550k.
78-550k
72-cb100
63 c100
75 xl350
84 gl1200
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #6 on: March 28, 2009, 04:21:16 PM »
JB weld and gas do not mix well. Just ask my old truck gas tank.
Offline pablo78cb550
  • mmmph.
« Reply #7 on: March 30, 2009, 03:13:42 PM »
i heli coiled a few of my float bowl screws. no problems.
Bikes in hand:
1977 Yamaha XS650
1978 Yamaha SR500 #119!
1978 Yamaha XS400
1978 Honda CB550K
1965 Ducati Monza 250
Sold off:
1992 Yamaha FZR600
1981 Yamaha Seca 550
Offline cb750fbomb
  • is by no means a
  • "No hope? See, that's what gives me guts!"
« Reply #8 on: March 30, 2009, 10:19:32 PM »
What happened to me is the soft alum. threads stuck to the screw that were used. I could unravel them with my fingernail. I got screws that were a little longer and it used threads that the old ones weren't using past the stripped threads. may be I just got lucky, but you can try it.
'77 CB750F2
“The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair.”
