Author Topic: clutch  (Read 922 times)
Offline themotoworks
  • addict
    • roc city cafe racers
clutch
« on: March 29, 2009, 04:14:00 PM »
weirdness is going on in my 400f clutch.  when I start the bike up, if I'm in gear not neutral, the back wheel jumps a bit, and when it's on the stand and running in gear with the clutch in, the back wheel will turn, slowly, but not with a lot of force.  the clutch is fully disengaged, and fully engages, so it's got full travel and when I pulled the clutch, all the plates and springs were in tolerance.  wtf?  I have a theory though... I think I overfilled the oil by a quart maybe, which I think is when the problem started, I drained about a quart out, until the dipstick level was right, but haven't ridden it since because the weather is still bad here.  so can extra oil screw with a wet clutch like that?
www.roccitycafe.com <- my sideline turned living
Offline Gordon
  • 750K1, 550K2
Re: clutch
« Reply #1 on: March 29, 2009, 04:32:35 PM »
That's completely normal.  With a properly adjusted clutch and the bike on the center stand, the rear wheel will spin with the engine running and the transmission in neutral.  It's an benign anomaly of the wet clutch system.
  • addict
Re: clutch
« Reply #2 on: March 29, 2009, 04:50:28 PM »
cool... it's weird that I rode that bike a year without it happening or without me noticing it
Offline Gordon
  • 750K1, 550K2
Re: clutch
« Reply #3 on: March 29, 2009, 05:08:39 PM »
If it wasn't happening, then your rear brake may have been out of adjustment.  If the rear brake is binding at all, it will stop the wheel from spinning while in neutral.
Also, this effect will diminish as the engine warms up (but won't completely go away).  When the oil is cold, it is more viscous and transmits movement more readily.  Once it warms up it loses some of that ability.
