It's hard to tell whether some of you are really thinking this plane won't fly, or if you're just pulling our legs. I could go all the way, and just state how stoopid you might be,but...
First, the original question says nothing about anything being different except the runway. One MUST assume that it's a regular plane, with regular ball bearing wheels, and that no brakes are being applied during take off. There are no trick questions like "what weighs more, a pound of feathers, or a pound of iron".
Then, there's a video. Proving that take off is possible. Yes, there is a tarp instead of a conveyor belt, but the tarp actually has more drag in it's endeavor to move in the opposite direction, assuming a conveyor belt is on some sort of rollers.
I appreciate that some have used humor. ( I know there is no spoon). I, too, am scared that some of you work on your own bikes. Not counting the converts, about 1/4 of you guys just don't get it. You seem to be fixated on an idea that the wheels create the speed and motion used for flight. Or maybe the aircraft carrier thing in reverse. As someone pointed out, a carrier points into the wind for take off, so if you are thinking the conveyor belt is moving the surrounding air, I can see your point. And yes, the conveyor belt does have some drag affect on the air, but no where near enough to have a measurable affect on the wings.
And it is a props job to move atmosphere. It moves air to create thrust. If it doesn't move atmosphere(air) how does a helocopter work?
I think copters are cool, Sebnn. Remember the TV show, Airwolf?
