Author Topic: Common mistakes in the English language and other curiosities  (Read 4232 times)
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
In case you were curious, or if it has been a while since you were in school...
The 3 'theres'
they're  <-->  they are -->  They're in the garage.
their  <-->  it belongs to them -->  The garage is theirs.
there  <-->  location  -->  The garage is over there.
you're vs. your
you're  -->  you are
your  -->  denotes possession  -->  That skid mark is yours.
(I always smile when someone writes "Your an idiot!")
two, too, to:
2  -->  two
to  -->  I'm going to the garage.
too  -->  Are you going to the garage too?
then vs. than
then  -->  Do this, then do that.
than  -->  Do this, rather than that.
But then again, it's better than that.
here, hear:
here  -->  Come here.
hear  -->  Did you hear me?  I said come here!
(Hearsay, not heresay)
'of' does not mean 'have'
should 'of' been  -->  should have been, or should've been.
Those damn apostrophes...
In a contraction (where two words are brought together), generally, apostrophes are placed where the first letter is missing.
Examples:
do not  -->  don't
does not  -->  doesn't
can not  -->  can't
This is not always the case though...
will not  -->  won't  (notice "ill" got dropped and we added an "o")
it's  -->  it is  -->  It's a nice day.
it's  -->  it has  -->  It's been a while.
its  -->  Every dog has its day.
Indicating possession (it belongs to someone):
That is Heffay's Yugo.
Billings' residents need to be careful when Heff rides through.
The above sentence is correct, but I'm told the following is also correct:
Billings's residents....
The use of multiple periods (ellipsis):
The rules are to use 3 or 4.
In general, they are used to emphasize a pause in speech, an unfinished thought, or at the end of a sentence indicating trailing off into silence.
For example, if a deep thought inspired the following sentence, I might put 3 periods at the
beginning:
...or it could be the carburetor.
If I want to emphasize further thought at the end, I would write:
I wonder if it's the carburetor...
If this sentence falls at the end of the paragraph, then I'd end it with 4 periods:
I wonder if it's the carburetor....
Use multiple periods when you quote someone, but only use part of the quote.  The periods replace the omitted words.
Example:
In 1969, the Honda Motor Company revealed the remarkable CB750, a machine that would change motorcycling forever.
"...the Honda Motor Company revealed the remarkable CB750...."
or the more correct (but more cumbersome)
"[...]the Honda Motor Company revealed the remarkable CB750[....]"
(In general, [] is used when inserting stuff into direct quotes.  Here, we use it to emphasize that the ellipsis are not pauses in speech, but omitted words.  I still prefer the less cumbersome version though.)
What in the Flip Wilson does e.g., i.e., and et al. mean?
They're Latin; the actual words are exempli gratia (e.g.), id est (i.e.), and et alii (et al.).
e.g.  -->  "for example"
i.e.  -->  "that is"
et al.  -->  "and others"
Punctuation... does it go inside quotation marks, or outside?
Answer:  Both, it depends on the situation.  But most of the time, it goes on the inside (except if you're British).
Examples:
Today, I saw Heffay and said, "Hey Hef, what's up?"
Heffay said, "not much," but I could tell he was up to no good.
Attempting to keep Heffay out of the hooscow, I told him he really shouldn't build that doomsday machine.
Heffay, unsure of what I said, asked me if I said "shouldn't"?  (Here, it would also be correct to place the punctuation inside the quotation mark, but I purposely put the punctuation outside when I want to emphasize the word, and not the word-punctuation combination.  In this example, when my character used the word "shouldn't" in this make-believe conversation, he used it more as a statement and not a question.)
" vs. '
Use " when you directly quote someone.
If the thing you're quoting involves an embedded quotation, then it goes like this:
"When I saw Heffay on his CB, he said, 'Look soichiro, no hands.'"
Outside of these set rules, in general, I use ' when I paraphrase someone (that is, not a direct quote, but I just relay to the reader the gist of what someone else said.  I do not claim that this is a set rule, but it's what I do).
General style:
Well, you know, I mean...
Here are some principles I try to use, but it's just my preference, not a rule per se.
I generally go for efficiency and clarity, without making it sound too boring.  People are more likely to read what you write (and understand it) if you keep it as short as possible.  Get rid of everything that doesn't contribute to the thought you're trying to convey.  Also, it's best, in an
argument, to convey only one thought at a time.
Here's an example.  The first draft, and then the edited version.
Well... if I were going to tune my carburetor, I would first check to see if the gaskets are still good.  I mean, if the gaskets are bad, then we're in trouble. The next step is to check to see if the jets are clogged.  You can do this by eye.  If the jets are clogged, then gas will not flow to the cylinders the way it should.
Edited for conciseness and clarity:
As a first step when tuning your carburetor, visually check the gaskets and jets.  Clogged jets restrict the flow of gasoline.
I could probably get away with just this:
Notice the elimination of those horrendous phrases like 'you know' and 'I mean'.
That f'n semicolon!
(From William Strunk, Jr. (1869–1946).  The Elements of Style.  1918.)
If two or more clauses, grammatically complete and not joined by a conjunction, are to form a single compound sentence, the proper mark of punctuation is a semicolon.
Examples:
1. Stevenson's romances are entertaining; they are full of exciting adventures.
2. It is nearly half past five; we cannot reach town before dark.
It is of course equally correct to write the above as two sentences each, replacing the semicolons by periods.
1. Stevenson's romances are entertaining. They are full of exciting adventures.
2. It is nearly half past five. We cannot reach town before dark.
If a conjunction is inserted, the proper mark is a comma.  (The 'conjunctions'
here are 'for' and 'and')
1. Stevenson's romances are entertaining, for they are full of exciting adventures.
2. It is nearly half past five, and we cannot reach town before dark.
Anyway, this is just for anyone who may have been wondering but was afraid to ask.  I'm no English professor, so take this with a grain of salt.  And don't worry... I don't judge anyone by the way they type.   ;D
« Last Edit: April 02, 2009, 03:56:13 PM by soichiro »
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
Offline goon 1492
  • Sucka Repellant
Re: Common mistakes in the English language and other curiosities
« Reply #1 on: April 02, 2009, 03:39:44 PM »
Wow that's alot of typing.
I do need a refresher course, and to those who don't know the G.E.D. classes aren't just for the ged folks they even encourage everyone to visit and touch up on keeping all that fresh in the head, I went several times just to study for free, good services to remember, even better than the library because they have teachers to help you and not a creepy librarian that probably has whips and chains in the back room...
well laid out soichro.
Offline Jonesy
  • Shop Rat
« Reply #2 on: April 02, 2009, 03:41:10 PM »
I think it's more fun to read a Honda owner's manual from the early 60's... ;D
(When was the last time you gave [...]big space to the festive dog[....]?)
Offline tramp
« Reply #3 on: April 02, 2009, 04:27:23 PM »
with all that going through my head
how can i sleep
or should i say thru
1974 750k
Offline alltherightpills
« Reply #4 on: April 02, 2009, 05:46:27 PM »
Ahh, but what about the Oxford comma?
I prefer to use it because I think it lends itself to more precision, but the choice is yours friends.  The choice is yours.
78 550K
77 550K (in pieces)
71 500K0 (in pieces)
Offline Caaveman82
  • Zippo
  • That'll do pig. That'll do.
« Reply #5 on: April 02, 2009, 06:01:08 PM »
Slaughter of the English language.
My eye balls pop out of my head when I hear "These ones" or "Those ones".
*cringe*
Offline Steve F
« Reply #6 on: April 02, 2009, 06:16:10 PM »
*cringe*
I'm with you on that one, one of my pet peeves.  It's either "these" or "that one" but not "these ones".
Offline Caaveman82
  • Zippo
« Reply #7 on: April 02, 2009, 06:18:33 PM »
*cringe*
See if there were such a thing as a double plural, all those idiots would be set!
Offline Steve F
« Reply #8 on: April 02, 2009, 06:29:41 PM »
Another one is when people use "their" for all three usages.  It's almost like they never heard of "there" or "they're".  Or when people use "to" when they mean "too", or when they say they're going out to fix the breaks on the bike (I'm not allowed to do that until brake time  ;D).
Offline 333
  • Time for change
« Reply #9 on: April 02, 2009, 06:39:26 PM »
Okay, my eyes rolled back in my head on some of those(ones ;D).  Who really cares how many periods one uses?  A trail of periods (to me, at least) is a way of expressing the phrase "uhh".  We all say it, but we don't type it.
The one that gets me is used on these custom car and bike building shows, where they describe a custom as a "one off", when it's really a "one of", as in one of a kind.   One off what?  If you made one off(assuming another), wouldn't there then be two?
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline Steve F
« Reply #10 on: April 02, 2009, 06:50:59 PM »
OOPs, I'm guilty of using that term :-[
(Time to go back to the airplane-on-the-conveyor thread.  See you there (or is it their or they're)).
« Last Edit: April 02, 2009, 06:52:49 PM by Steve F »
  • Tuck
« Reply #11 on: April 02, 2009, 06:55:27 PM »
Just stating the general rules.  If you were writing a novel, for example, you might care about it.
I guess I included that one because I use it all the time....  (D'oh!)
1974 CB 750
1966 Black Bomber
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #12 on: April 02, 2009, 07:51:06 PM »
What makes me cringe is when so many use "alot" instead of "many", especially professionals.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline Caaveman82
  • Zippo
« Reply #13 on: April 02, 2009, 08:01:27 PM »
That would piss me off too.
Espically since it's "a lot".  :-*
I know what you mean though...  :D
« Reply #14 on: April 02, 2009, 08:19:42 PM »
The farmer is sowing seed in the field, his wife is in the farmhouse sewing his torn trousers, what are they both doing?
Over to U. ;D ;D ;D ;D
sAM :-\
Offline gregimotis
  • poet laureate; SOHC4.
« Reply #15 on: April 02, 2009, 08:37:50 PM »
From 'Urban dictionary' (specializing in slang or recent-ish expressions)
1.     One Off
(n) a one time occurence. An ad-hoc exception to rule. Corporate jargon meaning that you'll do it once and not repeat.
Let's just treat this as a one-off and make sure it doesn't happen again.
ad-hoc one off one time exception repeat
Chiefly British.
-adjective
1. one of a kind; unique.
2. done, made, or happening only once.
-noun
3. a one night stand.
4. something done, made, or happening only once.
This began as a British expression but is now known in the US and elsewhere.
one off:
 unique singularity one night stand fling
A person you only plan to have sex with once. A one-night stand.
short for One of a Kind
Offline Frankenkit
  • Industrial Strength
« Reply #16 on: April 02, 2009, 08:44:14 PM »
THANK YOU, Soichiro!
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline Gordon
  • 750K1, 550K2
« Reply #17 on: April 02, 2009, 09:12:40 PM »
While we're on the subject:
-When you misplace something, you LOSE it.  Not LOOSE it.
-There's no such word as noone.
-When you witnessed an action or spotted someone and want to relay this to another
  person, you say "I SAW" it/them, not "I SEEN" it/them.
-The word is eSpresso, not eXpresso.
Offline Trevor from Warragul
« Reply #18 on: April 02, 2009, 10:19:32 PM »
Don't get me started on pronunciation!!
"Giggling" (two syllables)
Correct pronunciation: Gig - ling (two syllables)
Gen Y pronunciation: Gig - gul - ing (three syllables)...
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
Offline Gordon
  • 750K1, 550K2
« Reply #19 on: April 03, 2009, 06:24:32 AM »
Supposably
Expecially
Nucular (popularized by none other than the big W)
Using the phrase "begs the question" to mean "raises the question", when that's not even close to the correct meaning.
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
« Reply #20 on: April 03, 2009, 08:03:52 AM »
How about the Ebay language ?
     Prolly = Probably
    Crome = Chrome
Duel Disk = Dual Disc
 There is (are?) a bunch more that I come across on a regular basis, but I can think of them right now.
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
Offline gregimotis
« Reply #21 on: April 03, 2009, 08:18:44 AM »
I see this used incorrectly all the time especially by print newspapers and it bugs the crap outta me.
Either they don't know what it means, or they are too lazy to bother - People who supposedly know something about the language and expect to be taken seriously.
NEWS PEOPLE: It not the internet that is destroying your business model, it's the crap 'news' you keep putting out.  It's editorials in the news section, endless 'news' about the latest celebrity gossip (or even not so latest.  You'll clowns will go on for weeks about some chicks rehab even while there's an actual war on) reporters reporting on other reporters reporting, sloppy writing, two-thirds of your paper copy/ pasted from the AP (which isn't any good either), and I especially love the editorials where y'all whine about how us plebeians just don't appreciate print media anymore - like it's our fault you do a sucky job.
So Yeah, I'm getting news off the interwebs; but it's not because I don't know any better Mr. newspaper guy.  It's because I'm not going to pay a a dollar for a sorry-a** gossip rag.  Jeebus Mary mother 'o' god, I could do better news than you idiots...  Drunk.
We now return to our regularly scheduled thread
« Last Edit: April 03, 2009, 08:40:59 AM by gregimotis »
« Reply #22 on: April 03, 2009, 08:43:43 AM »
I think craigslist might be worse.  I am more likely to buy something from someone if I think they're literate.  :D
The funny thing is there are no rules that English (or any language for that matter) has to follow.  Linguists are descriptive rather than prescriptive.  So if enough people over a long enough time period use prolly instead of probably, it will become an "acceptable" word.  I put acceptable in quotes, because it is a relative term.  Acceptable to whom? (or is it who?)  You would get eviscerated for using prolly in an academic paper (and my wife, who is an English Lit prof, sees these words on a regular basis in her student's papers), but it is completely fine to use the word colloquially.  People often forget that dictionaries came much later than words and definitions in them, and that language will always change much quicker than dictionaries can.
The same goes for pronunciation. The Great Vowel Shift that occured in English between the 15th and 18th centuries is a good example.  Regional dialects greatly effect pronunciation, but no one would argue that people are mispronouncing words because of an accent.
78 550K
77 550K (in pieces)
Offline Frankenkit
« Reply #23 on: April 03, 2009, 08:53:57 AM »
I think this site iz in ur intrawebz, killing ur engrishes.
1973 CL350- Lola?
Stuff for sale
Offline Soos
« Reply #24 on: April 03, 2009, 09:03:31 AM »
I aint' don beeen speelin two bad eye thunk.
EEn koledg I wuz un inglesh mejur.
How culd I not speel korectli, I was burn 'nd razed in the good ole USA?
 ;D ;D ;D ;D ;D ;D
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
