Author Topic: Tire fitment on the front  (Read 1894 times)
Offline Burnboy
« on: April 03, 2009, 03:12:25 AM »
I have a '75 750. I am trying to fit a 16'' spoke rim on the front, the tire is a 130. obviously it is a snug fit as is. What are my options? So far I have thought of grinding a bit off the fork lowers but I don't think this will get me the clearance I need. My only other option seems to be widening the triple trees a bit and all that goes with that. Front end swaps are a bit out of the question unless I can still use my cb front hub as I have ordered custom spokes for it. Thanks in advance.
1975 CB750
1973 CB350F
Offline Burnboy
Re: Tire fitment on the front
« Reply #1 on: April 03, 2009, 05:14:10 AM »
Im digging info up on the gl1000 front end swap, but cant find if the front end is wider or not, anyone know?
If so...
Can I just get the gl1000 triple trees and use my cb forks, lowers, brakes, hub, axle etc...
Or could I get away with the gl1000 triples, forks, lowers, and axle, and use my cb hub and brakes? (upgrading to dual disk later)
« Last Edit: April 03, 2009, 05:23:54 AM by Burnboy »
1975 CB750
1973 CB350F
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
« Reply #2 on: April 03, 2009, 05:22:26 AM »
The GL front end is wider than the CB front end. You would want the complete front end off a 75-77 GL to keep your stock CB 6 bolt brake disc wheel.
 The GL has 37mm fork tubes and the stock 35mm CB fork tubes wont fit the trees (easily).
 I dont know if you can fit a 130 on the GL forks, but the GL forks have a lot more space betweeen the tubes than the CB does.
 The GL already has dual discs and getting a complete 75-77 GL front end would be the easiest thing to do (triples, tubes, brakes, axle and speedo drive).
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
Offline Burnboy
« Reply #3 on: April 03, 2009, 05:25:24 AM »
Thanks! the cb front end is about an inch shy of working. so I can still use my  cb hub with the gl1000 front end?
1975 CB750
1973 CB350F
Offline fishhead
« Reply #4 on: April 03, 2009, 05:31:15 AM »
 The 78-79 GL went to the later 5 bolt brake discs. The 75-77 GL front end will accept your stock CB 6 bolt brake disc wheel. The discs, axle, calipers and speedo drive is different on the GL so you will also need that. A complete 75-77 GL front end would be the easiest way to do it.
Offline Burnboy
« Reply #5 on: April 03, 2009, 05:44:51 AM »
Thanks again. Should I assume the gl1000 and gl1100 are not interchangeable?
1975 CB750
1973 CB350F
Offline Alan F.
« Reply #6 on: April 03, 2009, 07:47:44 AM »
A 16" tire on the front will reduce your trail measurement and possibly have a very dangerous affect on handling.  What size tire are you planning to run?  if you're going for the fat/thick front tire look, you may be alright as the circumference of the tire may not be far from stock.  Too little trail will make the bike very twitchy to ride at speed, added trail (like extended forks chopper style) will give you great straight line stability at speed, there's a happy medium in there somewhere that is a good combination of law speed handling and high speed stability.  I should also mention that the size of your rear tire and the length of your rear shocks will also affect your trail measurement.
Do your research before you build a bike that's hard to ride or worse...is dangerous to ride.
http://www.tonyfoale.com/
Offline fishhead
« Reply #7 on: April 03, 2009, 07:51:59 AM »
 That would be correct.
 Your main focus was keeping the CB ( 6 bolt drake discs) wheel/ hub and the 75-77 GL front end would be the easiest way to do it.
 Later forks would require modifications of some sort to get them to work with your early wheel/hub.
Offline Burnboy
« Reply #8 on: April 03, 2009, 10:00:23 AM »
they guys on honda chopper are saying a 130 should fit the goldwing front end can anyone else here confirm that before I start ebaying?
« Last Edit: April 03, 2009, 01:19:19 PM by Burnboy »
1975 CB750
1973 CB350F
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #9 on: April 03, 2009, 10:08:16 AM »
I have a 78K... 130 does not fit on my stock front end. Even with the fender out.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline Burnboy
« Reply #10 on: April 03, 2009, 01:19:50 PM »
sorry havoc, i meant can anyone confirm a 130 will fit the goldwing front end
1975 CB750
1973 CB350F
Offline 333
  • Time for change
« Reply #11 on: April 03, 2009, 01:31:03 PM »
If you can find a GL1200 (naked) front end, it will bolt on and already has a fat 16" wheel/tire on it.  The faired GL1200 might also work, but I don't know if it will look right.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline Alan F.
« Reply #12 on: April 03, 2009, 08:50:24 PM »
I calculate that the difference in tire radius between 100/90-19 and 130/90-16 is only .44 inches lower for the GL1200 tire size.  That should quicken up your steering without compromising low speed stability or handling at speed, that many racers can't be wrong.  Rock On.
Offline Burnboy
« Reply #13 on: April 04, 2009, 05:17:15 PM »
Yes the overall size is going to be near that of stock so not much is changing there.
Anyone with a gl1000 front end wanna grab a measurement for me?  ;D
1975 CB750
1973 CB350F
