Author Topic: cb500 carb problem again  (Read 908 times)
Offline emilios
« on: April 06, 2009, 11:13:13 AM »
Hi
i start up engine with the air level to position 1 (see foto) and engine runs ok at 2000 rpm...but
when i open the throttle and revs go up to 4rpm they stay there even if i close throttle....only if i turn
air level almost to position 2(if i turn total to position 2,engine stop) engine goes back to 2000rpm(i know that engine must run at 1000rpm idle speed but i found that problem first and thying to solve it).
Is my problem air leaks,throtle cables??????or something else?
Re: cb500 carb problem again
« Reply #1 on: April 06, 2009, 02:17:16 PM »
Position1 is normal run, 2 is for cold start only.
Sounds like youre carbs aint balanced properly
Offline 750goes
  • it will live
« Reply #2 on: April 06, 2009, 05:09:00 PM »
how clean are your carbs, and are the throttle slides sticky, cables lubed or hanging up somewhere ??
Offline emilios
« Reply #3 on: April 07, 2009, 06:53:19 AM »
Thanks guys
I just balanced carbs and all problems dissapear...
