After your bench synch (all slides open exactly the same amount at a given throttle setting) and you put your gauges on the carbs, are they close to being synched up? If not then start looking some more for air leaks, or mechanical issues with the engine. . . . If you can get things into good gauge based adjustment with just a bit of tweaking then . . . .When the the synch goes out of whack, have you pulled the air filters and checked to see if the #1 slide appears to be out of position, ie has it dramatically moved from where you set it during the bench synch? If so, look to OldSchool's stripped nut or linkage issues.
