Author Topic: Throttle  (Read 1002 times)
Hyseman
Throttle
« on: October 24, 2005, 03:28:47 AM »
I have a 73 CB750 and noticed that when the handle bars are turned completely to the right, my RPM's increase until the handle bars go back some. Is this normal or is there somthing wrong?
Offline mick750F
Re: Throttle
« Reply #1 on: October 24, 2005, 04:06:36 AM »
   Definitely not normal. Check your throttle cable for proper routing. Also make sure you have the proper length cable.
Mike
Glosta, MA
Offline 78_SaltLick
  • Honda 1974 550
    • Custom Drum making
Re: Throttle
« Reply #2 on: October 24, 2005, 04:23:05 AM »
i had that problem, my deal was that i had no play in the throttle, so when i turned the bars to the right i was leaning on the throttle a little which increased the rpms. If i had more play in the throttle, that wouldnt happen. Make sure you have some play in that throttle.
Gold sparkle is the place you outta be.
