Author Topic: cb750 gear ratios?  (Read 1476 times)
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
cb750 gear ratios?
« on: April 07, 2009, 07:38:56 PM »
I put a k8 motor in my k1, and used the same sprockets.
   Now the gear ratios seem closer and 5th gear cruises around 5200 rpms at 60 mph.
My question is, are the gear ratios different from 1971 to 1978, or am I imagining things?
Offline jaknight
  • ....Round Town Ride......
Re: cb750 gear ratios?
« Reply #1 on: April 07, 2009, 07:52:05 PM »
Hi IC,
The '77 & '78 had different gear ratios from the earlier K's as you got up into 4th and 5th gear...... they also had a different overall gear reduction.
Earlier K's Primary reduction = 1.708
     77, 78 Primary reduction = 1.985
Earlier K's 4th gear = 1.907
     77, 78 4th gear = 1.133
Earlier K's 5th gear = .939
     77, 78 5th gear = .969
Hope this helps..... ;)
~ ~ ~ jaknight ~ ~ ~
"THE PEN IS MIGHTIER THAN THE SWORD........
..........EXCEPT IN A SWORD FIGHT"
"There is nothing new under the sun.........But there are many old things we do not know"
BIBLE ---> Basic Instructions Before Leaving Earth
  • Like a well oiled
    • Undead Asphalt
« Reply #2 on: April 07, 2009, 08:23:40 PM »
ah, that explains it. thanks
ev0lution7
« Reply #3 on: April 07, 2009, 08:24:33 PM »
your motor in your profile looks like an "F"  you sure its not an f??
