Author Topic: Billet blocks....who will pay...pics added 9/7/09...10/24....2/10  (Read 195097 times)
Offline lordmoonpie
    • Moonpie
Re: Billet blocks....who will pay...pics added 9/7/09...10/24....2/10
« Reply #475 on: September 15, 2010, 06:48:15 AM »
Question for the experts. I am thinking about ceramic coating my pistons, am i correct in saying that i would only be able to coat the crown of the piston as they are already matched to the bore?
Thanks guys...
yes - unless you coat them and then hone the bores afterwards?
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
« Reply #476 on: September 15, 2010, 06:53:30 AM »
Thanks guys...
Oh...sure. ::) ;)
  • Moderator
« Reply #477 on: September 15, 2010, 07:08:36 AM »
How do they get that Teflon stuff to stick to the piston ???
Sam. :-\
« Reply #478 on: September 15, 2010, 03:05:59 PM »
Thanks guys...
Hi LMP, Nikasil bores mate .... ;)
Sam. :-\
I'm not too sure Sam but its supposed to drop temps quite a lot from what i have read....
« Reply #479 on: September 15, 2010, 06:16:49 PM »
Hey Eric, have you checked your tank clearance over those cam tower hold down bolt thingies? They're massive!  :o
Hi Terry or should that be G'day
Hmm, they sure do look a bit tall don't they. However, I took the view that's its a great deal easier to cut things down to size rather than trying to add a bit on. Fear not, the cover will be going under the milling machine before too long and those bolts will get the chop as well. I'm just waiting for Mike to send me a cam so that I can get the engine finished.
Cheers
Eric
No worries Eric, I just would have hated for you to install your tank for your first big ride and then realise that it's (possibly) not going to go on. I'm running a Megacycle 125/75 cam in my 836cc engine with one of Mike's heads and it's brilliant above 6000 RPM thru to redline, but has virtually no bottom end or mid-range punch, so I'll be installing a milder "torquier" cam next winter, as 6000 RPM is around the upper limits of my normal street riding. Cheers, Terry. ;D
« Reply #480 on: October 09, 2010, 12:46:46 PM »
 I have 1 block available. It is finished for 71.25mm JE pistons. Ready to bolt up.
Offline BLUE71TURBO
« Reply #481 on: October 09, 2010, 04:35:11 PM »
  Hey Mike,  is that cylinder nikasil coated or iron bore ?    ;D
« Reply #482 on: October 09, 2010, 08:46:34 PM »
Nikasil.
« Reply #483 on: October 10, 2010, 03:04:07 AM »
If thats your one Mike, how come you are selling it..?
Offline BLUE71TURBO
« Reply #484 on: October 10, 2010, 02:15:56 PM »
 It kinda sucks that the bore is 71.5mm instead of 71mm. The cylinder would go good with mikes 71mm A.P.E.'S pistons he has for sale.
 If only the pistons were flat top turbo pistons !   ;)  :D
« Reply #485 on: October 10, 2010, 02:31:26 PM »
They are flat tops.
« Reply #486 on: October 10, 2010, 02:31:58 PM »
its 71.25 not 2nd over..
Offline BLUE71TURBO
« Reply #487 on: October 10, 2010, 11:22:24 PM »
 OOPS !!  My mistake !!   Hey Mike, I saw another add of yours for a billet cylinder and 71mm pistons. Is this the same set ?  Also you
 said the pistons are flat tops.  What compression ratio are they ?
  • Moderator
« Reply #488 on: October 11, 2010, 03:56:48 AM »
Thanks guys...
Sam. :-\
I often wondered how they got it to stick to frying pans when It's surposed to be none stick. ;D ;D ;D
Sam. ;)
« Reply #489 on: October 11, 2010, 06:11:41 AM »
Thanks guys...
Sam. :-\
Sam. ;)
 ;D ;D   Good point.....
Offline BLUE71TURBO
« Reply #490 on: October 11, 2010, 07:15:28 AM »
Sam. ;)
[/quote]
      Here ya go Sam ........................http://www.answerbag.com/q_view/82420       ;D
  • Moderator
« Reply #491 on: October 11, 2010, 09:17:19 AM »
I wonder why my piston coater didn't tell me he had to go to all that trouble to stop my pistons sticking to the bore ;D ;D ;D ;D ;D
Sam. ::) ;)
Offline imabass
« Reply #492 on: November 02, 2010, 03:13:55 PM »
Not quite finished yet, but looking good.
Cheers
Eric
Wow.  Nice work.  I got a hard on that can be seen from space.
  • Moderator
« Reply #493 on: January 07, 2011, 05:46:16 AM »
Has anyone got one of these big bad boys near ready to run ?
Sam. ;)
Offline sparty
  • I just play one on TV
    • Gallery
« Reply #494 on: January 11, 2011, 08:50:06 AM »
I have the same question Sam.  I would like to hear one roar down the road.
Sparty
1972 CB750 K2 Cafe' Style
  • Moderator
« Reply #495 on: January 11, 2011, 09:06:02 AM »
Who are you mate? I knew a member named Sparty ages ago. :D :D :D :D :D
How's it going dude? ;)
Sam. ;)
Offline sparty
    • Gallery
« Reply #496 on: January 11, 2011, 04:16:06 PM »
Sam. ;)
I am doing well Sam.  I hope the same is true for you.  Haven't posted much - but have been lurking on the forum.  Now that my Hot Rod is finished I am on to other non-motorcycle related projects.
« Reply #497 on: January 11, 2011, 09:23:22 PM »
Someone tell that man about the Relay Rally Across America, Canada and Beyond!! Hot Rods are especially welcome to join in the fun.
Hi Art. Good to see you again.
Jerry
Offline wannaby
« Reply #498 on: March 11, 2011, 08:14:53 PM »
When you said block I thought ya meant the bottom end not barrels think this guy could machine the bottom end cases without the tranny to build a Kind of inline indian four style cafe racer ....not that I could afford it....but a cool project...kind of along these lines...D
« Last Edit: March 11, 2011, 08:25:59 PM by wannaby »
Offline Tintop
« Reply #499 on: March 28, 2011, 02:36:02 PM »
So I figured this was the place to post the news, that a JMR billet barrel now resides in Canada. ;D ;D ;D
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
