Getting Mike to post pictures is nearly as difficult as getting you to post them Frank. Sam.
Quote from: SamCB750A on January 04, 2010, 12:20:21 AMGetting Mike to post pictures is nearly as difficult as getting you to post them Frank. Sam. That's the pot calling the kettle black.
Be proud my good man, not too shabby.
Weight is as follows........Raw=61lbs Operation 1=42lbs Operation 2=20lbs Finished=15lbs. 3 lbs lighter than the stock (18lb) block.
Not great pics but I think you can see the top and bottom work,
Hi Mike, great work mate. Do i have this right, these will be even lighter with the nikasil bores as opposed to sleeves....Mick
Mike,VERY nice. What is left to finish on those blocks - anything? You carved those by hand with your Dremel right? Did you try a test fit to the cases and head? I'd like to see a picture of that. I am sure everyone would also...I'll be waiting for the dyno test results.Art
