just wondering why you chose a cb360 frame? is it just what you had or is it a matter of fit? do you think this moto mill would fit in something small such as a cb450 frame? i'm very intrigued by this engine and am thinking about frame options; i also wonder if it's (the 600 or 500) related to the gb500. had a chance to buy one new in 1988 and passed it over. what a boob i am.
sorry for picking your brain about this again. what's the latest with your thumper? is the motor ok?
Ecos,
I had the 360 frame plus a title that goes with it.
The 360 engine went into an earlier 3-wheeler.
The engine is a little tall for the frame but I'm sure it weighs less than the original 360 motor.
I think the '83 version that I have was that only one with 2 carbs.
It is essentially the same engine that's in the GB500.
Mine is 589 cc's.
The engine is dry sump so you'll need to add an oil tank to whatever frame you choose.
I also replaced the rear swing arm with a longer one
inorder to move wheel back and give room for the oil tank.
A heavier frame might be be a good idea since I can feel flex
in the 360 frame when the hammer is dropped.
The engine does seem to be O.K. --after it's brush with death.!
Phil
