Author Topic: Would this m/cyl improve CB550 braking?  (Read 1227 times)
Offline anparkinson
« on: April 12, 2009, 01:09:52 AM »
The link below is for a Goldwing master cyl with a 14mm bore?
What is a standard CB550 bore?
If this piston is larger would it increase the bite on the disc for the same amount of pull or not? Obviously more fluid would be displaced but would the extra effort required to shift this extra fluid offset any advantage?
My CB550 disc is pretty good with rebuilt caliper (stainless steel piston), rebuilt m/cyl, sintered pads and braided lines, but it would be nice to improve them further without resorting to the twin disc setup and the extra unsprung and inertial weight that brings.
Or has anyone fitted any other m/cyl which has made a good improvement?
http://cgi.ebay.com/ebaymotors/FRONT-BRAKE-MASTER-CYLINDER-GL1000-GL1100-GL1200-GL1500_W0QQitemZ140312659244QQcmdZViewItemQQptZMotorcycles_Parts_Accessories?hash=item140312659244&_trksid=p3911.c0.m14&_trkparms=72%3A1205%7C66%3A1%7C65%3A12%7C39%3A1%7C240%3A1318
Re: Would this m/cyl improve CB550 braking?
« Reply #1 on: April 12, 2009, 02:27:44 AM »
Standard 500 is 14mm bore and wing ought to be 17
Offline hymodyne
« Reply #2 on: April 12, 2009, 03:42:29 AM »
I upgraded to this M/C and am very happy with it.
hym
Offline Jay B
« Reply #3 on: April 12, 2009, 06:06:43 AM »
hym
+1. Really improved performance, also easier to mount drag bars.
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
Offline edbikerii
    • Gallery
« Reply #4 on: April 12, 2009, 07:17:43 AM »
Depends on the model year and braking configuration.  The GL1200 has linked brakes, which means that the front brake lever operates only the left front disk, and the brake master cylinder is only 14mm.
I have used the advertised brake master cylinder on my CB550, and it worked perhaps slightly better than the stock master cylinder.
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
« Reply #5 on: April 12, 2009, 11:07:30 PM »
Never worked on a wing with linked brakes so cant comment, if so the sellers description is wrong but i do know the 1000 wing has a bigger bore than a 500 and i have used them on twin disc setups to get more fluid moved
