Author Topic: WANTED: MAGNUSON 110 SUPERCHARGER  (Read 8991 times)
Offline BLUE71TURBO
« on: April 12, 2009, 07:12:29 PM »
I WANT TO BUILD A SUPERCHARGED CB750. I HAVE A 71 WITH AN ATP TURBO SET UP
WITH AN A.R.D. CDI MAG DRIVE. 25 LBS OF BOOST WITH VP RACING FUEL. 970 CC'S
SCARY FAST !!  DOES ANYBODY HAVE A MAGNUSON 110 FOR SALE ANYWHERE?
Offline AHuff
Re: WANTED: MAGNUSON 110 SUPERCHARGER
« Reply #1 on: April 12, 2009, 07:54:52 PM »
Nope, but I have an old keyboard with functioning caps-lock key if you need it.
Offline robe0531
« Reply #2 on: April 12, 2009, 07:58:39 PM »
lmao
1978 cb750k
1968 Honda ca160
Offline cafe2be
« Reply #3 on: April 13, 2009, 05:47:00 AM »
Blue, Can you please take pics of your turbo set-up. I am interested in boosting my 77 750f. Thanks!
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
« Reply #4 on: April 13, 2009, 10:47:53 AM »
Maybe check over at Dragbike.com if nobody here has one.
Pics and performance specs please!
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
Offline JLeather
« Reply #5 on: April 13, 2009, 10:56:51 AM »
Blue,
  What pistons and rods are you running with that combo and what did your static compression come out to?  I'm finishing up my turbo engine and I'm still not sure which way to go on the pistons.
Offline Really?
« Reply #6 on: April 13, 2009, 11:17:17 AM »
LMAO
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline BLUE71TURBO
« Reply #7 on: April 15, 2009, 11:35:00 PM »
Blue,
I'm running RC forged steel rods, mtc 8.25 compression pistons, 970cc bore. With vp
racing c-16 fuel, 25lbs boost is the most i've run so far. The A.R.D. cdi belt drive magneto
really helps with the spark at high boost levels and makes it sound different. Only fires
1 spark plug at a time, not 2 like stock ignition. I'm also running a SU carb from Rivera
Engineering. I'd post a picture but haven't learned how yet. Maybe soon.
Offline JLeather
« Reply #8 on: April 16, 2009, 04:30:29 AM »
Yeah, the MTC low-CR pistons were part of the ATP "competition" turbo kit.  I've been looking for a set for a while now, even called MTC, but I haven't been able to find a set.
Offline NitroHunter
« Reply #9 on: April 16, 2009, 08:00:31 AM »
I'm loving this one!  ;D
Which turbo, compressor and turbine A/R? How big is that SU carb? What is your timing?
Just a thought, the boost sounds just right for a Rajay F compressor. Check your compressor map, the flow at that pressure is a little high for a B.
Just think of the boost levels / air flow we could generate if single turbos could support higher pressure ratios!
« Last Edit: April 16, 2009, 08:19:24 AM by NitroHunter »
Offline BLUE71TURBO
« Reply #10 on: April 16, 2009, 10:55:32 AM »
You will probably have to bite the bullit and have some pistons custom made. I should of
bought the MTC big block way back then like a friend of mine did. 1200cc !! His is
turbocharged also. Hey, email me your address and i'll send ya some pictures of ole blue !
maybe you could post them on this site for me. Here's mine: JON.GAGE@HOTMAIL.COM
Offline Ricky_Racer
« Reply #11 on: April 16, 2009, 12:38:32 PM »
Hey, Jon. Is this the one?  RR
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #12 on: April 16, 2009, 01:02:43 PM »
RR if that is yours....
I'm going to find you..... kill you..... and take that home.
 ;D ;D ;D
Lucky bastard.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline Ricky_Racer
« Reply #13 on: April 16, 2009, 01:43:25 PM »
Well, okay then Havoc. Just bring it on to SoCal...
Now if I can just afford to build the rest of the bike!   :-\  RR
« Last Edit: April 16, 2009, 01:53:34 PM by Ricky_Racer »
Offline hymodyne
« Reply #14 on: April 16, 2009, 05:02:30 PM »
 ;D ;D ;D
Lucky bastard.
that was the laugh I needed today...
many thanks
hym
"All things are ready if our minds be so."
Offline TheHun
« Reply #15 on: April 16, 2009, 05:21:37 PM »
mechanical fuel injection?
1978 Honda CB750-K
CBR F3 Coils
Kerker 4.1 Header w/ turn down
Maxi-Dwell Ignition
Foam Air Filter Pods
Superbike bars
Starter Delete
CARB CLEANING/REBUILD: http://www.wix.com/TheHun/CarbCleaning-Site
Not Running to Running, doing the work yourself= Priceless
Offline BLUE71TURBO
« Reply #16 on: April 16, 2009, 06:42:58 PM »
YES !! That is it! Is it yours? and is the setup for sale ?
Offline Ricky_Racer
« Reply #17 on: April 16, 2009, 08:41:50 PM »
Hi Jon. Thanks, I wasn't sure if it was an 80 or a 110. With the extra ribs I thought it was probably a 110.
I chased for years to find a Magnusen setup. I even spoke with Jerry Magnusen and never could locate one with a complete CB750 clutch drive.  He doesn't own one either, and would love to find one for himself.
This setup was mounted on a Kaw drag bike, but with a side support plate similar to my Drouin it should be an easy fit to a CB750. I was planning on using a Weber 45 sidedraft with this unit.
For sale?  I suppose that everything is at some point.  Drop me a PM with a contact number if you like. We should probably get to know one another since we're obviously both about half crazy!   ;D  RR
Offline jx25
« Reply #18 on: April 16, 2009, 10:10:21 PM »
LMAO
but on a serious note, did someone get his pics to post them yet, gotta see this setup
1978 CB750K (slightly modified)
1973 Suzuki GT250
1968 Ducati Monza 250(needs title)
1965 Bultaco 250(needs clutch work)
Offline Big Jay
    • CBRzone
« Reply #19 on: April 16, 2009, 11:26:11 PM »
Did that blower and injector come from Dragonfly?
Offline BLUE71TURBO
« Reply #20 on: April 16, 2009, 11:58:50 PM »
Thanks for the reply RR ! Couldn't you drive the blower off the crankshaft. My best
friend has an old buddy that has a setup like yours that is driven off of the clutch.
He first had it running off the crank  and he made his own injector setup ! he's a
engineer at San Onofre nuculear power plant. He ran his on alcohol ! He also made a
special swing arm to convert it to a 3 wheeler for Glamis sand dunes. It finally gave
in the ghost and blew the trans out the bottom of the cases !! I've been trying to
buy his setup for years but he says he's going to bring her back from the dead !!
Hey get this, My friend who has the shop has a complete 4 port Hilborn injector setup
with the pump, all brand new !!! Same thing though, wont sell it. At least not yet.
  I'm really trying to find someone who has a digital camera and can show me how to post some picture's of my turbo'd honda.
« Reply #21 on: April 17, 2009, 05:40:47 AM »
 ;D ;D ;D
Lucky bastard.
Are you talking about the dog in the first pic?? ;) ;D
Offline Ricky_Racer
« Reply #22 on: April 17, 2009, 07:05:57 AM »
Hi, Jay. Sorry, I'm not acquainted with "Dragonfly" but my blower came from the East Coast. RR
B71T, that seems like to easiest way to drive the blower; off the dyno side with a block-off plate and a remote (Goldwing?) alternator. At least that's the way I've been planning the project. I don't see any down side compared with a clutch drive. The motor will be balanced off with an RC drive and Hunt/Vertex magneto.
I still have the same problem as everyone else who's looking at an aspirated engine: pistons. I've got a set of Golden Rods I'd like to use so the DOHC 750 rods are currently an "if necessary" option.
Anyway, due to more critical priorities (survival!) this is a back-burner project, but one that is so outrageous that I have to try to do it.
BTW, has anyone ever seen a bottom end "girdle", either internal or external, made for or used on a CB750 SOHC?  Where is the case weakest under extreme use?  Anybody?
This forum has some great minds. Thanks to everyone who participates in SOHC4!!!
 ;D ;D ;D
Lucky bastard.
Whatever... It's not my dog!   :D  RR
Offline Big Jay
    • CBRzone
« Reply #23 on: April 17, 2009, 09:14:49 AM »
Then I might know where there is another one.
Jay
Offline BLUE71TURBO
« Reply #24 on: April 17, 2009, 10:09:47 AM »
Hey JAY! If ya do come across one for sale, email me with the info would ya?
