Author Topic: Glass beading cases and leaving them natural. Pros and Cons  (Read 4193 times)
« on: April 14, 2009, 02:52:47 PM »
I'm still bouncing around about what to do with my cases (CB750K2) on my project. 1. Clean really well and paint over existing paint, which has some stains and flaws. 2. media blast and paint, or 3. media blast and leave natural (appealing)  4. media blast and powdercoat (that's what my powdercoater wants me to do.)
pros and cons?
What do natural cases do if left plain? Do they discolor over time?
I have this terrible aversion to paint. I can get over it if i have to.  ;D
Offline Magpie
Re: Glass beading cases and leaving them natural. Pros and Cons
« Reply #1 on: April 14, 2009, 03:30:01 PM »
If you media blast use something like soda that will melt away with water. I've been warned off glass beading many times by my mechanic because of the difficulty in getting rid of the glass beads in the case passage ways after the beading is doneHhe says no matter how much you clean the beads still show up later. I would use a strong chemical cleaner, even Simple Green, and rinse it well.
I did use a strong degrease which took the paint off too.
I prefer painted cases but that's just me. I've used Duplicolor Engine Enamel 1615 and been happy with the match to the original color. A buddy has just used on his CBX and is very pleased with the finish as well.
Here's a picture of a K0 engine that I used the degreaser on. You can see the difference between the bare case and the painted part, the bare case almost has a yellow/light gold color.
Cliff.
« Reply #2 on: April 14, 2009, 03:35:39 PM »
4, 2, 3, 1 would be my choices. Powder coaing would be the most durable. They don't have to lay it on thick. Thinner is better for heat transfer. The coater will do all the prep work to ensure the job is right. ie blasting and pre-baking then bake the finish. You just take them dirty engine pieces. I'd think bare blasted aluminum would look great initially but tend to easily stain. If you're going to spray it yourself I'd definitely blast it first since you're going to all that trouble. It will look better and the paint will last longer. I just left the powder coater. With the money I'm spending I'll go the powder route. I was quoted $275 just for the head and jugs which are the harder more technical parts to do. On the other hand if you have a cabinet and spray paint it'll cost you maybe 30 bucks. If you're just coating the cases you should get by relatively cheaply.
Offline kghost
« Reply #3 on: April 14, 2009, 04:27:58 PM »
Well.....
This subject has been debated many times....
First. If you leave them bare they will corrode. Period end of story.
How do I know? Well I have a stack of cases of various honda engines.
They corrode just sitting. Inside. Without alot of moisture.
Second. I've bead blasted cases. A lot of the outcome depends on what bead you use.
Notice I did not say SAND.
Yes. Glass bead is a pain in the butt to remove from all the passage ways and screw holes.
Start with a Very clean case (oil, grease, and Solvent free)
I use a set of engine bore brushes and alot of scrubbing.
Third Your powdercoater better be prepared to spend alot of time and tape/plug it up right.
Its labor intensive to make it come out right.
Do it wrong and you'll have powder coat inside. Do it wrong and you'll have powdercoat cracking off at bolt holes and case edges.
I spent 9 hrs taping and prepping my cases. Lots of silcone plugs and fiberglass tape.
I used a set of covers ( right and left) to seal the engine up when the powder was applied.
I took them off prior to pushing it in the oven.
Preheat the cases at least once...they can have a tendency to outgass.
Powdercoating is time and labor intensive VS painting. However done right you can wash your bike with a hose and simple green  ;) Its also impervious to gas and most solvents.
Wanna know how something works? Ask someone who's done it
Been there done that...take it for what its worth.
Stranger in a strange land
« Reply #4 on: April 14, 2009, 04:39:10 PM »
Thanks all, that brings it back home. KGhost I unnerstan.  I think I've gone full circle and I'm back to cleaning it real good by hand and painting over the existing paint.
The powdercoat is appealing, and I don't doubt its stout, but i don't see how it can be done without a lot of prep as you say.
And blasting is going to require cleanup as well.
Still open minded, but I think I know where I'm going.
I need to suck it up and learn about painting.
« Reply #5 on: April 14, 2009, 04:43:34 PM »
I pained mine and if you use an enamel, gas is not a problem. Powderecoating has some problems.
Offline kghost
« Reply #6 on: April 14, 2009, 05:30:49 PM »
What was the last thing you had powdercoated?
I'm currently beating the hell out of at least two powdercoated bikes.
No issues. No chipping, no peeling, no nothing
You've posted before about what a pain or problem powdercoating is/can be.
Back up the statement.
Maybe the problem is the powdercoater or the prep.
Not stirring you up or causing a rumble but come on man....show us something or speak from experience.
Offline lordmoonpie
    • Moonpie
« Reply #7 on: April 15, 2009, 04:47:34 AM »
Bead or vapour blast every time. It leaves the cases bare sure but, contrary to some opinions here, the glass beads finely peen the surface leaving a slightly better than satin finish that doesn't really deteriorate. My bomber cases were done in 1999 and it gets some right proper weather racing in the UK - still shiny and nice, no corrosion.
You get the usual oil stains with burnt on oil but they clean off quicker as they aren't penetrating the peened over surface.
If your blaster is good and you meticulously clean all holes and threads afterwards, you can easily get rid of the glass and you have a great finish too.
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
« Reply #8 on: April 15, 2009, 05:47:27 AM »
For a really nice finish bead blast the entire piece, dump the bead and replace it with new bead and go over the piece again. Really nice finish.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #9 on: April 15, 2009, 07:54:16 AM »
I've considered powder coating too, but was unsure if the baking temp would distort the crank bores.
FJ
« Reply #10 on: April 15, 2009, 08:00:26 AM »
FJ
Indy Powder Coating, with whom I am/will be/maybe dealing, say they do it all the time. Lots of examples, mostly Harley customs. But same fears apply: prep, masking, cleanup, baking. I guess its all in a days work.
Offline kghost
« Reply #11 on: April 15, 2009, 09:05:51 AM »
FJ
I haven't seen any of that.  Baking temp is about 400 degrees....which is below where the aluminium would soften.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #12 on: April 15, 2009, 09:35:42 AM »
Thanks
« Reply #13 on: April 15, 2009, 10:56:39 AM »
My love of podwercoat stems frorm buying some very expensive outdoor furniture that had been powdercoated, three years later I was at it with a can of Rustoleum. I am not alone since the Northeast is damper than the Mexican border.
The car restoration guys jumped at powedercoating frames until it peeled and they recieved customer beefs, or their own franmes chipped and rusted. It is hard to repair. Now theyt use the twpo part POR paint.
Powdercoat came about to circumvent the EPA regulations on VOC emissions and waste removal restrictions. It was tried in the Rail industry for the wheel trucks, the abrasive dust and vibration shook it right off. So now two part paint is used.
You want to powder coat a lamp to sit on the end table, that is cool. Maybe some cabin area panels on planes. But for things exposed to harsh environments. I think not
Offline kghost
« Reply #14 on: April 15, 2009, 12:40:09 PM »
My love of podwercoat stems from buying some very expensive outdoor furniture that had been powdercoated, three years later I was at it with a can of Rustoleum. I am not alone since the Northeast is damper than the Mexican border.
Not talking planes.....
Talking bikes.
Ok so you had a problem with patio furniture and Moisture.
I'm curious to learn why your patio furniture peeled.
(by the way...steel powdercoated in a marine environment is generally etched and phosphated. This is a step many places skip.)
Do you think it was the moisture or perhaps was there some part of the process or skipped part of the process) that made it especially susceptible to moisture?
Of course Powdercoat can chip.....so can paint. If either chips or is compromised....Rust is the result.
As a general rule edges are worse then large areas. Same as paint.
I've found that in general Powdercoat is more chip resistant then paint. When I say chip resistant I mean normal wear and tear.
Powdercoating is far superior to paint in terms of abrasion resistance.
Things that would chip and scratch paint do not seen to affect powdercoat.
Same thing for repeated wear applications. (abrasion resistance)
As far as repair goes....once powdercoat is chipped your kinda screwed. Paint it to match.
The purpose of paint or powdercoating is surface protection...the byproduct of which is beauty.
If I were a betting man I 'd venture that the problem associated with Railroad wheels had to do with the Mechanical interlocking of the applied layer to the wheels coupled with the extreme forces and environment.
Perhaps it was a problem with the application not diffusing into the substrate.
Paint has an edge up in both those.
Primarily this is due to Powdercoating being a "Dry" paint. There is generally no prime associated with the powdercoat (hence no chemical means of surface adhesion as you would have with an etching primer or a phosphate or zinc precoat. Think galvanized)
Bear in mind that many industrial/manufacturing places use a Thermoplastic Powdercoat vs a Thermosetting Powdercoat.
Also bear in mind the different types of powder coat.
There's Epoxy, Urethane, Polyester, and Acrylic. Same as paint because bear in mind powder coat is "dry" paint.
I'd bet your patio furniture was done with the cheapest process and cheapest type that was available to the manufacturer.
Anyways...Metal corrosion can be halted mechanically or chemically.
Take your pick.
« Reply #15 on: April 15, 2009, 01:21:46 PM »
OK enough of that, this thread is about ME!   ;)
Many here have mentioned soda blasting as an alternative to glass beading, never really clicking why. So I was calling around today, asking about this and that, and one powder coater referred me to another stripper saying they used soda blasting, among everything else, and it was water soluble. So the light goes on. Quick Google on sodablasting explains it to me:
http://www.ace-sandblasting.com/soda-blasting-article.html
In the back of my mind, I really want to strip it bare, but I didn't want the cleanup. Looks like I may be on to something. I've got an email into IDSBlast for an explanation. But if its what it sounds like, that's what I'll do.
« Last Edit: April 15, 2009, 01:25:40 PM by MCRider »
« Reply #16 on: April 15, 2009, 01:25:07 PM »
Well the virtues of Powdercoat escapes me. And to be honest with you it means almost nothing to me. That was just my 2 cents. I do like anodizing.
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #17 on: April 15, 2009, 01:25:29 PM »
Many here have mentioned soda blasting as an alternative to glass beading. So I was calling around today, asking about this and that, and one powder coater referred me to another stripper saying they used soda blasting, among everything else, and it was water soluble. So the light goes on.
I really want to strip it bare, but i didn't want the cleanup. Looks like  I may be on to something.
By far the easiest to clean up after. But you dont get quite the finish that you get from glass or other media.
Don't get me wrong, it's not drastically noticeable, but if you've blasted a few thousand parts and then suddenly look at soda.... you'll see the difference.
Dunk your parts in about 150 degree water for 20 minutes to take care of everything and rinse. Done.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
« Reply #18 on: April 15, 2009, 01:27:19 PM »
The Soda blasting may provide a pleasing texture for whatever you put on top of it.
« Reply #19 on: April 15, 2009, 01:28:08 PM »
Since with a bare surface, I'm OK with painting it, the finish is not a probem. But i do see what you mean. Thanks.
« Reply #20 on: April 15, 2009, 01:30:43 PM »
And I'm just kidding around some too. I do appreciate the comments. My powdercoated lawn furniture is rusting after 3 years as well. I do attribute it to a lesser level of care in production. But who knows till you try?
I'm powdercoating the frame for sure. Maybe I won't be happy after wards, but its the experience.  The engine I'm not so keen about.
« Reply #21 on: April 15, 2009, 02:24:50 PM »
As we say in NY. Not for nothing, but I panited my frame with $16 worth of Rustoluem enamel which looks very original. I spent the saved money on a Dyna ignition and most of the new tires.
Offline kghost
« Reply #22 on: April 15, 2009, 02:31:08 PM »
Plenty of people have painted thier bikes with Rustoleum.
Personally I can spot a paint job like that from 20 ft.
Depends what your after.
Offline HavocTurbo
  • Can you tell?
« Reply #23 on: April 15, 2009, 02:53:22 PM »
Compared to powdercoating yea it'll be noticeable.
But if you buy enough of the rustoleum and put 10 or 12 coats on it... looks factory and thicker.
But nowhere near as thick as powdercoat.
09 XL883L - No Name
Offline mcuozzo
  • Bottle in front of me or frontal labotomy?
    • 77 CB750K - needs total rebuild
« Reply #24 on: April 15, 2009, 02:56:33 PM »
Soda blasting will work for removing paint and light rust anything worse than that and it might have a tough time removing it.  Also it does not "etch" the surface.
Most powder coaters use some media that is angular in nature (aluminum oxide, coal slag).  This creates a surface that has been mechanically etched.  It provides a better surface for the powder coat to adhere to.  For painting it may leave the surface too rough though.
This picture shows what I'm talking about.  Both brackets were painted black (and had a little rust on them).  The left one has been partially soda blasted.  The right one has been blasted with coal slag.
You can check out my gallery http://gallery.sohc4.net/main.php?g2_itemId=306724 for other exmaples.
« Last Edit: April 15, 2009, 03:00:28 PM by mcuozzo »
