Author Topic: Stator wire connection order  (Read 766 times)
Offline NCSUEngineer
« on: April 16, 2009, 05:54:37 PM »
A small bit of background to explain.
Catastrophic stator/field coil ejection.
Stator wires mauled.
New Stator.
Cut wires -> new spade connectors connecting mauled wire to stator. (a spade male/female in each yellow wire between stator and connection)
Question is - does it matter which yellow wire (from stator) plugs into which yellow wire  (on its way to the rectifier)....I don't think it does - but i thought i would check!
Thanks!
Re: Stator wire connection order
« Reply #1 on: April 16, 2009, 06:35:51 PM »
There is no order significance.  Each wire's AC voltage gets converted to DC becomes common at the output of the Rectifier.
