Author Topic: When I pull these off , what will happen ???  (Read 1952 times)
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« on: October 26, 2005, 01:26:56 PM »
Hello ,
I am in the painting mood , and was looking at the bike to see what I could pull off and paint.
I have attached some pics of the pieces I want to rip off and paint , but i am not sure what is
behind those covers I want to remove.
I was always taught to ask first , then remove , so thats what I am doing  ;D
Is their just gonna be oil behind those covers , or are springs and small parts
going to fly everywhere like old Harley's ??
As usuall , all help is appreciated.....
Offline dusterdude
Re: When I pull these off , what will happen ???
« Reply #1 on: October 26, 2005, 01:33:30 PM »
teal,i like your artwork
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
eldar
« Reply #2 on: October 26, 2005, 01:36:00 PM »
Well in picture 1 it is the clutch cover. Remove whenever the mood strikes.
Picture 2, the cover on the front is your stator cover. You might get a small dribble of oil but ok to remove just becareful of wires. The back part I forget, I think some oil will come out but I can think of it right now.
Offline ProTeal55
  • Est1968.com
« Reply #3 on: October 26, 2005, 01:46:25 PM »
DusterDude ----> Photoshop is pretty nifty huh ?
Offline dusterdude
« Reply #4 on: October 26, 2005, 01:55:07 PM »
yea,i dont think im quite there yet
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline jtb
  • An unlikely
« Reply #5 on: October 26, 2005, 06:37:51 PM »
Teal, You'll lose a little oil when you pull the tranny cover (next to the stator cover), but not much.  I had mine off last week, and wiped it up with a paper towell, so it's not bad.
John
1977 CB750F
1985 V65 Sabre
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #6 on: October 26, 2005, 07:04:40 PM »
Photo #1
left side clutch..remove at will
right side of photo,  points..remove at will
Photo #2
....you will get some oil leakage
Offline Jonesy
  • Shop Rat
« Reply #7 on: October 26, 2005, 07:44:18 PM »
On photo #2.. when you remove the rear (transmission) cover, you will be able to disconnect the 3 yellow, 1 white, and 1 green wire that go to the alternator- which lives under the frontward cover. If you remove the alternator cover first, the wires will keep it from being removed more than a few inches from the motor! When putting it back together, the 3 yellow wires can go back together in any order, but the white wire has to go to white and the green has to go to green.
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
« Reply #8 on: October 28, 2005, 06:51:40 PM »
I always pull the covers 1st, then ask questions.
2009 Suzuki TU250
2014 Honda Grom
1988 Yamaha FZ600
2018 Honda Ruckus
1971 Honda CB500
Offline dpen
« Reply #9 on: October 31, 2005, 03:06:37 AM »
1- good idea to pull the clutch cover occassionally to check the clutch adjustment.
2- pull the tranny cover occassionally and give it a clean around the sprocket. You wouldn't believe the amount of crap that gathers there and it all goes onto your nice clean chain.
cd811
« Reply #10 on: October 31, 2005, 05:47:05 PM »
after ya pull the stator cover, you might have to replace the gasket. good place to start an oil leak.
Offline Clyde
« Reply #11 on: October 31, 2005, 10:12:50 PM »
The wires for connecting the alternator to the wiring are behind the transmission cover in photo 2 and you should remove the transmission cover before the staor/alternator cover.
Be careful reconnecting these wires as posted above. Ensure the connectors are pushed in properly otherwise it will mean doing it again. I once made this mistake and only just got home on the battery!!!!
It would be wise to have a alternator/stator cover gasket and a transmission cover gasket before you do this.
You probably will get a small amount (<100cc) of oil from these covers. A drip tray is good in case the non return valve leaks and you have a wet sump. This can be reduced a bit by leaning the bike over to the right, before starting this work
The covers in photo 1 are for routine maintenance adjustment on the clutch and points. You need to check them regularly and adjust if necessary
Regds Clyde
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
