Author Topic: CB550 carb balancing result  (Read 1011 times)
Offline anparkinson
« on: April 27, 2009, 09:33:55 AM »
When I stripped my carbs for my 550K3 down last year I set the balancing up with a feeler gauge so that all 4 butterflies where exactly the same amount open, thinking this would be a good starting point.
Last week I hooked up a set of vacuum gauges to set them up exactly. All were identical and there was no need to adjust any. To double check I did adjust one and immediately it showed on the gauge so I put it back where it was originally.
Was I just lucky or is this a fairly safe way of doing it with feeler gauges?
Offline Chester345
  • will someday be an...
  • 76 CB750F
Re: CB550 carb balancing result
« Reply #1 on: April 27, 2009, 09:47:52 AM »
I think that's the accepted way to bench set them.
Indeed you are powerful.
Nicely done, lucky bugger!   ;D ;D
Offline Deltarider
« Reply #2 on: April 27, 2009, 12:44:42 PM »
I share your experience. Over the years I've benchsynced my carbs three times and when checked afterwards, difference in vacuum was never over 2 cm Hg. That's well within spec. I haven't used my set of manometers ever since.
Eh... butterflies ???
« Last Edit: April 27, 2009, 01:16:38 PM by Deltarider »
CB500K2-ED Excel black
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: April 27, 2009, 01:01:16 PM »
"The Force is strong with this one."
mystic_1
- John Augustus Shedd
