Author Topic: stripped brake line fitting in caliper......Helicoil possible?  (Read 18904 times)
Offline sinister902
    • Anger Street Kustoms
as the title states.....I managed to strip the threads trying to bleed the front caliper cause the bleeder is snapped off from previous owner, and the threads stripped right out on me.....I have been trying to locate a cheap caliper, but if I cannot find one.....can I get away with a helicoil?
Markcb750
Re: stripped brake line fitting in caliper......Helicoil possible?
« Reply #1 on: April 27, 2009, 05:36:22 PM »
I would check here
http://www.emhart.com/products/helicoil.asp
email/online tech support is available.
WHALEMAN
« Reply #2 on: April 27, 2009, 05:48:43 PM »
I am not sure this would work but an idea I had would be to buy a speedbleeder in a larger size and then use a blind tap to thread the hole. Dan
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
« Reply #3 on: April 27, 2009, 05:49:17 PM »
I wonder if you could go to the next larger pipe thread and, if worse comes to worse, just use a plug instead of the nipple-type thing...
If you do this though, make sure you re-tap it with a tapered thread (NPT - National Pipe Taper).
http://www.engineeringtoolbox.com/npt-national-pipe-taper-threads-d_750.html
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
Offline themotoworks
  • addict
    • roc city cafe racers
« Reply #4 on: April 27, 2009, 06:04:26 PM »
i think a helicoil would work, as long as the seal is good.  i've fixed them before by drilling out the threaded hole, turning a piece of aluminum and press fitting it, then rethreading... worked well
www.roccitycafe.com <- my sideline turned living
Offline cappy
« Reply #5 on: April 27, 2009, 06:08:22 PM »
I have had much success using TimeSerts.  Look them up on the web.
Basically they are a thin wall sleeve that uses the same pitch of thread but oversized diameter (solid piece sleeve)
GTR1400 KAWASAKI CONCOURS 08'
T500 TITAN 75'
YZ250 82'
CB550 77' BUILDING
Offline sinister902
« Reply #6 on: April 27, 2009, 10:35:51 PM »
i must clarify, i stripped the threads for the brake line itself going into the caliper, not the bleeder.....the bleeder was snapped off by previous owner, so i was bleeding using the line, and stripped the threads out......and after looking at pictures of helicoils, i dont think they will work in this application. I need a CB550 caliper......
Offline jaknight
  • ....Round Town Ride......
« Reply #7 on: April 27, 2009, 10:46:49 PM »
Hey sin's sister, ;)
You might try checking the SpeedBleeder site itself.  I seem to recall that they had a procedure there for fixing a stripped thread hole.  I can't recall what the procedure was, but I am sure they at least at one time had a fix procedure there.  See what they recommend.......
Just a thought, you never know....... ;) ;)
Edit AddOn.... Well, I guess SpeedBleeder has removed that section; I did a search there and couldn't find it ??? ???
~ ~ ~ jaknight ~ ~ ~
« Last Edit: April 27, 2009, 11:39:12 PM by jaknight »
"THE PEN IS MIGHTIER THAN THE SWORD........
..........EXCEPT IN A SWORD FIGHT"
"There is nothing new under the sun.........But there are many old things we do not know"
BIBLE ---> Basic Instructions Before Leaving Earth
« Reply #8 on: April 27, 2009, 11:42:47 PM »
I wouldnt helicoil that thread, caliper from 350, 360,400 four, 500 four and twin and 550are all the same
WHALEMAN
« Reply #9 on: April 28, 2009, 02:12:17 AM »
These threads are not pipe thread. Dan
« Last Edit: April 28, 2009, 02:14:29 AM by WHALEMAN »
Offline Toxic
« Reply #10 on: April 28, 2009, 03:47:46 AM »
So if it doesn't work and the seal lets go while your riding you're in a world of trouble.
keep looking for a replacement caliper.  They are out there.
Not a chance I would take.
jinshiyang
« Reply #11 on: June 15, 2009, 11:12:33 PM »
and after looking at pictures of helicoils, i dont think they will work in this application.http://www.xhcljx.com/eng
« Reply #12 on: June 16, 2009, 07:49:30 AM »
This wont look stock, but you can tap it to a metric banjo size or NPT, then install an adaptor to braided line & be back in business.
Offline bikebitzofvt
« Reply #13 on: June 16, 2009, 09:25:26 AM »
I recall seeing a stainless insert to repair damaged bleeders.  I think it was in a H-D aftermarket supplier's catalog.  It looked nicer than this:
http://www.truechoice.com/prodinfo.asp?number=BLEEDER+KIT
But, this should fix your problem...
Good luck!
"If it ain't broke you aren't riding it hard enough!"
77 CB750K7, 77 KZ1000B
« Reply #14 on: June 16, 2009, 10:29:36 AM »
I have to agree with Bryan...there are so many used calipers out there it isn't worth the time to try and repair it (which very well might not work in the end anyway.) Plus you said the bleeder was screwed up too.
Offline sinister902
« Reply #15 on: June 17, 2009, 10:45:55 AM »
I did in fact find a replacement caliper for $40, and went that route. Thanks for the help guys!
« Reply #16 on: June 17, 2009, 11:07:13 AM »
You did the right thing. ;)
Offline Raul CB750K1
« Reply #17 on: June 18, 2009, 12:43:30 PM »
My .02 in this issue.
I had handlebar switches installed in my Sanglas bike. When I fitted the mirrors I found out that what seemed to be good thread were indeed ruined- the mirror locknut will snap with the slightest torque.
So I found myself in your same dichotomy: buy new switches or helicoil. Sure, there are plenty of switches out there but I would have to remove the handlebar and reroute the wires, while helicoil is just a matter of five minutes.
I could buy used switches and find out that the threads were bad too, and after all, didn't we enjoy these challenges? replacing is the easy thing to do, restoring and repairing is what it all about.
Contrary to the opinions here, I think a helicoils would work perfectly on the banjo bolt of the brake caliper. Why? because the sealing is done at the crush washer, and even when you need to drill to a bigger size, it is not that big of a difference. And even if it is, you can always use a bigger washer of the same diameter (10mm), as you don't replace that banjo bolt often.
So you opted for replacing. Guess what did I opt for... :-)
« Reply #18 on: June 18, 2009, 05:07:31 PM »
Raul.. BIG difference between a through hole,
 and a  Shallow hole with a  seat (that is CRUCIAL)  for sealing..
« Reply #19 on: June 19, 2009, 07:24:00 AM »
From what I understand, it was not the bleed nipple what was stripped, but the hole for the banjo bolt for the brake line. There the sealing is made at the washer if I'm not wrong.
Even if it was the bleed nipple, as the sealing is done at the seat, much better. You only need to drill carefully and insert a short Helicoil, as it has proven stronger than aluminum threads, to guarantee you will have a strong seat of the nipple against the seat.
Not trying to beat a dead horse, but I really think there is nothing wrong in repairing a brake caliper -as long as you can easily find Helilcoil of such a fine thread-
« Reply #20 on: June 19, 2009, 07:32:45 AM »
Nice to see apost from you Raul....where have you been? If the bleeder is that messed up I would question the condition of the tapered sealing surface. I'd guess it is galled and in poor shape. Another thing is the cost of a helicoil set (insert tool, tap and inserts)......they are not cheap and if a shop did the job it would cost the same as a replacement. I like Helicoils and use them all the time on heads but there is an initial investment involved. ;)
« Reply #21 on: June 19, 2009, 07:36:52 AM »
As an aside, a standard tapered Helicoil tap will not work with a shallow hole. You need to purchase an STI bottoming tap.....more cost ;) ;D
« Reply #22 on: June 19, 2009, 07:38:39 AM »
Helicoils dont work well in shallow holes.
 The PO stripped his brakeline threads (steel line) in a 550 caliper.
 He could tap to the bigger banjo thread by removing the seat & probably drilling right thru.
 But helicoiling, stock fitting to cone threads, not enough room.
Even if you ground a second tap, to more of a bottoming style, you still lose a bit of room as the end of coil must have full thread (when installed). If you ever ran a helicoil too shallow & had the lower part of thread undersize, you will know what I mean.
« Reply #23 on: June 19, 2009, 07:46:45 AM »
I know what you mean. The bottoming taps I use only lose about 1 thread (if that). Helicoils have their limits but I've found you can use them just about all the time.
« Reply #24 on: June 19, 2009, 07:47:59 AM »
A few words on repairing stripped bleeders. After you get it out IF there is any meat left in the seat area..
Sometimes you can go to a bigger bleeder,  the trick though is to fixture up, and after oversize drilling the thread hole, touch up the seat. This requires a 90 deg included angle c-sink (available from KBC)
 If the seat is gone , there is one more option that works on some calipers. Accel used to make a replacement seat&bleeder, The drill correct size to tap to 7/16 thread, tap & install. Use sealant to seal in insert, or dont cut thread right thru, that allows it to jam on the last tapered threads..
 I have saved a few calipers..
