Hey ASC, I'm from Yorktown as well, nice to see someone local on here.
I am currently in the process of outfitting by CB750 K7 with fatter front and rear tires, as I too like the beefy look. There are a lot of folks on here that overstate the difficulty fitting wider tires. With the stock rims you are limited primarily by the width of tire supported by the narrow rims.
I wanted a 17" front rim to get a more modern sporty look, so what I did was remove my stock rear rim (2.5" x 17") from the rear hub, and have re-laced it to my stock front hub. Then I found a 4.5" by 17" harley rim on ebay for $50, and laced that to my rear hub.
I've got both new wheels sitting in my living room, and just received my tires. They're avon roadriders, 120/80/17 for the front, and 150/70/17 for the rear. The 120 will fit up front no problem between the forks on the 77k, and the 150 will fit in the rear with no mods. The rear rim will support up to a 170 tire, but that wide I will have to shift the brake stay to prevent rubbing (very easy mod to do) and MAYBE get an offset sprocket, but it doesnt look like this will be the case.
I also removed my front and rear fenders as I think it cleans up the look greatly. The 120 front tire may not fit with the stock fender anyhow.
