Author Topic: CB750K7 Nine Lives Cafe Racer - au revoir  (Read 141755 times)
Offline brandEn
Re: CB750K7 Nine Lives Cafe Racer - Fender, Seat Mod, Details
« Reply #200 on: October 16, 2013, 10:34:45 AM »
If your using the original switch check the white plastic part on the back/bottom. Those just snap on and mine came off causing a similar issue. I used epoxy to hold it place.
« Reply #201 on: October 16, 2013, 12:41:19 PM »
Yes, mine is the original switch.  I'll give your "fix" a try.  Thanks, brandEn.
« Reply #202 on: October 20, 2013, 01:41:27 AM »
I didn't get a chance to swap out the ignition switch today.  I was too busy riding the K7 for the first time in 4 years!  It was a blast.  I took it easy, since the motor was just broken in on the dyno, but had fun riding it for about 100-120 miles.
The front end is much improved from the stock CB750.  The GL1000 forks combined with the more robust DCC upper triple and the Telefix fork brace provide much more stability through the turns, and the GL1000 brakes seemed to be getting better as I scrubbed them in.
Here are some photos of the bike near the closed MCAS Tustin blimp hangers:
Some video of the exhaust
Offline brandEn
« Reply #203 on: October 20, 2013, 06:16:10 AM »
Looks and sounds great!
Did you support the back off the pipe to the passenger peg mounts?
Offline ogsmakdade
  • bike newb
« Reply #204 on: October 20, 2013, 07:39:34 AM »
glad to see you're finally able to enjoy your bike again.  ;D
exhaust sounds great.
Everyone thinks Chuck Norris is bad, but Chuck Norris has not meet Lucky either.  Lucky will round house kick Chuck back to 1969 and pop a wheel with the 1st sandcast while shotgunning a PBR!
My "build" http://forums.sohc4.net/index.php?topic=126537.0
« Reply #205 on: October 20, 2013, 09:42:54 AM »
Exactly.  We welded an almost invisible bracket that bolts right to the peg mounts.  I originally built the bike with 2 up riding as an option.  That's why I chose a soft padded speed hump for seat, and I did not cut off the passenger peg mounts.  My better half is not a big fan of riding on the back so I'm planning to replace the seat with something more aesthetically pleasing to me.
« Last Edit: October 20, 2013, 10:47:21 AM by CB750 Cafe Racer Fan »
« Reply #206 on: October 20, 2013, 11:08:13 AM »
Some additional pictures of the bike.  What a great weekend for riding.  I wanted to get some more saddle time before I get back to working on the bike to finish it.  Next up, the seat swap and fender, then if the weather gets cold (below 60), I will send the headers out for ceramic coating.  I also need to work out some electrical gremlins -- the headlight is not working but the bike is charging fine.
« Last Edit: October 20, 2013, 12:19:43 PM by CB750 Cafe Racer Fan »
« Reply #207 on: October 20, 2013, 12:26:42 PM »
One of the annoying details to take care of.  The gas tank lid was mounted slightly to low to the hinge, so that it was rubbing and cracked the paint on the hinge.  I'm having Bondo respray it, since he's also working on the fender and seat.
« Reply #208 on: October 20, 2013, 12:32:52 PM »
Here's a shout out to Rob aka Voxonda for his beautifully machined pre-load adjusters for the GL1000 (37mm) front end
Offline brandEn
« Reply #209 on: October 20, 2013, 12:36:18 PM »
Your gonna coat those beautiful SS headers? Man they look awesome like that!
« Reply #210 on: October 20, 2013, 12:46:13 PM »
Stainless only looks good bare for so long, then it starts discoloring.  You can start to see the yellowing of the metal, after the bike was broken in on the dyno and tuned.  The ceramic will keep a consistent finish.  I suppose I could ceramic coat them a metal finish, but I think I am going to go with a black satin akin to my first pipes.
« Reply #211 on: October 21, 2013, 10:38:46 AM »
Thanks.  I cannot tell you how encouraging it was to fire it up and ride the bike.  It definitely got me excited and more motivated to get the rest of the details sorted.  I can't wait to ride it again.
« Reply #212 on: October 21, 2013, 11:36:49 AM »
Wow, great results! Doesn't a fresh 750 engine sound great?! No rattles, tight. Good work.
« Reply #213 on: October 21, 2013, 02:41:23 PM »
I'm more happy about no leaks!
Offline KrautKoffin
« Reply #214 on: October 21, 2013, 03:05:53 PM »
Bike looks great! Congrats man!
74 cb550
I now have Beastie Boys "Sabotage" stuck in my head after seeing your avatar.
Offline Vincent
« Reply #215 on: October 21, 2013, 09:55:00 PM »
Hey, sharp-looking bike, Don. And I love that sound. I agree with you about ceramic coating the pipes, and that's what I'll do with mine. Where will you take them?
« Reply #216 on: October 21, 2013, 10:01:50 PM »
Thanks, Vincent.  It has a bit of pop/backfire on deceleration/engine braking, but it sounds really good, especially when you go above 4000 rpm as you begin going into the sweet spot.
Most likely, I will take the pipe to Embee Performance in Santa Ana.  (http://www.embeeperformance.com/)  They have a great selection of finishes and they seem to do a solid job.
« Last Edit: October 21, 2013, 10:04:26 PM by CB750 Cafe Racer Fan »
« Reply #217 on: October 25, 2013, 07:13:55 PM »
I guess I can't leave well enough alone.  I committed on changing the seat.  I'm swapping out the bigger seat built on my stock pan for a beautiful sheet metal seat fabricated by Ian Halcott of Cafe Seat and Tank/House on Fire Industries.  I got her mocked up today.  My tank needs a repair on the flip cap, so I also decided to add some silver pin-striping to highlight the knee dents.  I'm also going to bob the 1978 CB750F fender so it is not so long.  The seat, tank and fender will carry over the same paint -- house black with some ghosted ice-pearl checkers.  Here's a picture of the mock up:
Offline Vincent
« Reply #218 on: October 25, 2013, 10:09:15 PM »
Don-
Good choice on the seat/tail. I think that proportionally it's more in keeping with the rest of the bike. The other setup was kind of bulbous, but this one has a good 70's race bike look. Very cool.
Vincent
Offline RustyOlive
  • rustyolive.com
« Reply #219 on: October 26, 2013, 04:11:10 AM »
Agreed. New seat continues similar proportions and lines as the tank. Also looks more agressive or as Vincent mentioned=70's race bike. It's a better fit sir. Kinda dig the raw steel look though. Lol i'd clear it, or punch out another in alloy. Hahaha.
Offline KrautKoffin
« Reply #220 on: October 26, 2013, 01:18:26 PM »
Looking great Don!
74 cb550
« Reply #221 on: October 26, 2013, 02:15:27 PM »
Vincent, Cam and Jordan,
Thanks for the thumbs up.
I think the new seat's size fits the proportions of the rest of the bike better than my old seat using the stock pan. I'm also bobbing the fender in keeping with the rest of the bike. The paint work should be finished in a out two weeks. I will have to ride my RC51 until then.
« Reply #222 on: October 26, 2013, 02:18:01 PM »
FYI - my HT Moto seat is available. If anyone is interested, PM me. It has the stock mounts for the frame.
« Reply #223 on: October 26, 2013, 08:12:40 PM »
Off topic: I just saw the new BMW Nine-T at Roland Sands Design today.  Brand new model, not yet on the market, but RSD has developed some trick parts for it.
Offline brandEn
« Reply #224 on: October 26, 2013, 08:21:33 PM »
That tail section looks much better.
I have met Ian before, he used to own Twinline up here in Seattle. Only met him once but he seemed like a cool dude and he loves old bikes. Those metal tail sections he makes are great quality.
