Author Topic: CB750K7 Nine Lives Cafe Racer - au revoir  (Read 208480 times)
Offline Prez1967
  • Adding lightness...
Re: CB750K7 Nine Lives Cafe Racer
« Reply #450 on: July 03, 2014, 08:25:06 AM »
Wow, just found this thread. What a story and a fantastic looking bike to boot! I've gotta ask about those rotors were they for the GL model? I have a extra stock calliper for my K7 and really would like to do the conversion. I'm a newish rider and these 70s brakes are a little scary!
I'd start by adding a stainless line to the factory setup.  I've seen the difference such a move makes on other bikes and believe it will be enough to improve the braking on this bike without going overboard.
Now if you still want the double calipers for other reasons, by all means.
« Reply #451 on: July 03, 2014, 09:03:05 AM »
drpoyser,
Thanks for the compliment.  The front end is from a 1976 GL1000.  I swapped to the GL1000 front for two reasons, improved handling and braking.  I had problems with my dual disc 750 front end.  The GL1000 offers a turn-key solution that simply swaps in place (calipers, rotors, forks, triple trees, etc.).  I originally had the stock rotors, cross-drilled by "el cheapo" one of the forum members.  I happened to get a great deal on EBC rotors, which are floating rotors and are much lighter, so I upgraded.  My master cylinder is not stock either -- but a modern Brembo radial master cylinder.  It stops MUCH better than any stock 750 and better than a dual disc 750.
Prez1967 makes a good point.  Many members are fine with the stock brakes.  At a minimum, I would recommend cross-drilling and resurfacing your used rotor, rebuilding your master cylinder and replacing your old brake lines with new braided stainless steel lines.  These upgrades will definitely improve your braking performance.
IF you decide to upgrade to a dual disc set up, I would recommend a GL1000 front end swap OVER a second 750 brake caliper and rotor.  Fitment of the second disc and caliper can be challenging to get the spacing right, and requires you to source longer bolts to mount both discs to the hub.  The GL1000 front offers some substantial improvements:  stronger brakes (bigger pistons) and improved handling (37mm fork tubes instead of 35mm).  It is a plug and play solution.  While you have the front end off, you can also replace your steering bearings to roller bearings.  There are lots of 75-77 GL1000 front ends available (if you buy the entire front end, it will be cheaper than buying the individual components), and it simply swaps into place.
Initially, I used the stock rotors, which I had crossdrilled by member el cheapo.  Not leaving well enough alone, I upgraded the rotors to EBC floating rotors.  They are lighter and are floating discs (as opposed to the stock discs), and I got a great deal on the rotors.
« Last Edit: July 03, 2014, 11:04:14 AM by CB750 Cafe Racer Fan »
Offline drpoyser
« Reply #452 on: July 03, 2014, 11:06:13 AM »
Nice one. I've already installed new taper bearings. I might leave the GL front end for now as I just had my stations re chromed at quite a cost! Would the EBC's just swap in on the 750 front end also?
Sent from my iPad using Tapatalk
« Reply #453 on: July 03, 2014, 11:31:26 AM »
Neither the GL1000 stock rotors nor the EBC rotors for the GL1000 will fit on a 750 front end.  The offset of the rotors for the GL1000 is larger (further distance from the hub) than the 750.  As a result, the GL1000 rotors will not line up with the 750 calipers.  Also the GL1000 rotor is slightly thinner (not so much of a factor).
EBC does make a few rotors for the 750 models.  According to the Dynoman website, EBCs Model MD1062 is specific to a 750K7-K8 and 750F (75-76).  (http://www.dynoman.net/brakes/ebc-apps.html)  I wasn't aware that there was any difference between the K0-K6 rotors and the K7-K8 -- and I am still not aware of any difference between any of the rotors for the K1-K8.  The F rotors for 77-78 are definitely different from all others.  When I was looking for one about five years ago, I could not find anyone stocking these rotors so it was a moot point.
There is a seller on ebay listing them for $185 right now.  (http://www.ebay.com/itm/EBC-Replacement-Rotor-Honda-CB750F-1975-1976-CB750K-1977-1978-/111288392576?pt=Motorcycles_Parts_Accessories&vxp=mtr&hash=item19e94e1b80#ht_2022wt_1362)  Another one selling for $179 (http://www.ebay.com/itm/EBC-ProLite-Front-Brake-Rotor1976-78-Honda-CB750K7-Left-Side-MD1062LS-/170893838924?pt=Motorcycles_Parts_Accessories&vxp=mtr&hash=item27ca110a4c#ht_1587wt_1362)
Note: EBC only seems to make these rotors for the Left Side.  If you ever went with EBC rotors in a dual disc 750 set up, you could (in theory) use a LS on the right side, but the cross-drill pattern would face the opposite direction and look wonky.
« Last Edit: July 03, 2014, 11:49:47 AM by CB750 Cafe Racer Fan »
Re: CB750K7 Nine Lives Cafe Racer - Moto Channel Video
« Reply #454 on: July 04, 2014, 11:53:40 PM »
Bruce MacKown, who produces videos of motorcycle builds under The Moto Channel on YouTube shot a video of my bike a couple of weeks ago.  There are also a bunch of great bikes on his channel, including forum member Doctor D, Jay LaRossa and others.  Aside from the awkward guy in the video (me), it's pretty cool.
I hope you guys enjoy it.
http://youtu.be/VVo5299mCgA
http://themotochannel.com/
<iframe width="514" height="290" src="//www.youtube.com/embed/VVo5299mCgA?version=3&amp;hl=en_US&amp;rel=0&showinfo=0" frameborder="0" allowfullscreen></iframe>
« Last Edit: July 05, 2014, 05:34:42 PM by CB750 Cafe Racer Fan »
« Reply #455 on: July 05, 2014, 12:19:45 AM »
You did well Don, not too awkward at all... ;)  You had to find a false neutral for the camera too i noticed... ;D :o
« Last Edit: July 05, 2014, 12:25:26 AM by Retro Rocket »
« Reply #456 on: July 05, 2014, 12:28:45 AM »
Thanks!  Unfortunately that made the edit.
« Last Edit: July 05, 2014, 12:30:29 AM by CB750 Cafe Racer Fan »
Offline Tews19
  • I am no
« Reply #457 on: July 05, 2014, 04:22:11 AM »
Great video CB750!
1970 Honda CB750 survivor.
« Reply #458 on: July 05, 2014, 04:24:07 AM »
Very well done Don. Great bike, great vid to boot.
« Reply #459 on: July 05, 2014, 07:15:51 AM »
Ladies and Gentlemen, may I introduce to you, our newest member, Hollywood Don!  :D
I just want to know, did you have to read the list of all the mods from a script, or was that truly from memory? Petty comprehensive description. I couldn't tell if you were pandering for sympathy about all the trials and tribulations you'd gone through to get the bike to it's now, beautiful stage? Or were you just documenting for insurance purposes  ;)
Seriously enjoyed the vid and walk around. Lots of great looking details and to see/hear it in motion is a very in treat.
Cheers-
Bruce had me give a description of all the current mods on the bike, but trying to remember and recite the 5-6 year history of mods with no list or script was a challenge. Looking back, a list really would have come in handy.
Offline riverfever
« Reply #460 on: July 05, 2014, 09:25:40 AM »
Seeing pics of your bike is always nice but seeing a video was awesome. Thanks for sharing Don. Nicely done.
« Reply #461 on: July 05, 2014, 05:36:14 PM »
Cal,
I never thought of the insurance angle, but that's a pretty practical use for it!
Offline Trad
« Reply #462 on: July 05, 2014, 08:30:07 PM »
Don, that was super well spoken. Great job! The bike looks killer as always.
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline Prez1967
« Reply #463 on: July 06, 2014, 06:17:40 AM »
Excellent video!
The inspiration from this bike just keeps flowing...
« Reply #464 on: July 06, 2014, 09:29:17 AM »
The coolest thing of all is that Bruce spent a good 4 hours shooting the video and stills, and he gave some great "beauty" shots of the bike.
« Reply #465 on: July 06, 2014, 11:59:50 PM »
Thanks, everyone, for the compliments.
The bike has been running solid. Between rides on the 550 and 750, I haven't had any time to ride my modern bike.
Offline riverfever
« Reply #466 on: July 07, 2014, 07:29:53 AM »
Beautiful photos Don. Are those mirrors functional? Meaning can you see anything without having to move around on the bike?
« Reply #467 on: July 07, 2014, 07:51:58 AM »
Keep the SOHCs and give it to your nephew  :) why spoil him with one of you one beauties? Make him earn their ownership!
Hah! A v-twin superbike for a 17-year-old. I'm sure he would like it but I would be disowned by my entire family. It look some significant seat time before I started riding that beast. It is a LOT of bike.
I'll probably start him with an enduro.
« Last Edit: July 07, 2014, 07:56:39 AM by CB750 Cafe Racer Fan »
« Reply #468 on: July 07, 2014, 07:55:01 AM »
Not so much. I have to move my forearm up to see around it. I will likely buy the bar end adapters so I can re-mount them with better clearance.
Offline brandEn
« Reply #469 on: July 08, 2014, 09:57:13 AM »
So I just checked out the video. I really like your bike, its one of my favorites. The video has me wondering a couple questions. You may have covered it in your thread here but I couldn't find the answers. I know you got new forks tubes but are they shorter? Did you get shorter springs as well? I also noticed you have the speedo drive but its not connected. How does your speedo read the speed?
« Reply #470 on: July 08, 2014, 11:15:27 AM »
Hi Branden.  Thanks!  I did purchase new fork tubes from Forking by Frank.  I had them make me tubes that were approximately 1 3/4 inches shorter than stock, since the GL tubes are so much longer than the 750 tubes.  Race Tech took the shorter length into account in selecting the springs for my weight, too.  I do not think that the springs are shorter, but have less tension.  Otherwise, the springs for your regular weight in a shorter tube are too stiff.
I eliminated the manual tach and speedo drives.  The tach is read directly from an output wire from the Dyna 2000.  I think you can have it also take a reading off of the coils if you have a Pamco or Dyna S.  The speedo reads off of a magnetic pickup unit on the wheel.  The opposite pickup is next to the left brake caliper.  You can see the line leading to the pickup runnning downward wrapped around the left brake line:
« Last Edit: July 08, 2014, 11:32:08 AM by CB750 Cafe Racer Fan »
Offline brandEn
« Reply #471 on: July 08, 2014, 11:37:57 AM »
Yea that unit is pretty slick. Thanks for the response. I wish I would have gone with the shorter forks and custom springs on my GL conversion.
« Reply #472 on: July 08, 2014, 12:43:04 PM »
The Acewell meter by itself isn't half as sharp looking without the cool Joker Machine billet housing that Richard Warren agreed to sell me -- one of his spares when he made a similar housing for his show bike.
« Reply #473 on: July 28, 2014, 04:39:31 PM »
I am running aftermarket fork gators on this bike, but the quality is turning out to be less than stellar -- I can see some cracks forming on the creases.  It's been so long that I cannot even remember where I got these, but they do not require the fork ear and fork leg fittings.
Does anyone have a recommendation for similar gators that will not crap out on me?  DCC vs. Cycle X?
« Last Edit: July 28, 2014, 04:43:11 PM by CB750 Cafe Racer Fan »
Offline Trad
« Reply #474 on: July 28, 2014, 07:08:29 PM »
Don, how do you like the LED headlight? I'm debating one myself. They look great and I hear the output is stellar.
