Author Topic: Ignition coil.  (Read 1343 times)
Magua
Ignition coil.
« on: April 28, 2009, 03:14:06 PM »
I've got a new coil for my bike, but unfortunately the wire colours of the new don't match with the old. It's a non genuine coil, new from david silver. https://www.davidsilverspares.co.uk/parts/part_28546/ One black and one black with a white stripe on the new, one green and one yellow on the old. For my cb400n 1980.
Any ideas as to how to which way it should be connected? No reply from davidsilver.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Re: Ignition coil.
« Reply #1 on: April 28, 2009, 03:54:09 PM »
I honestly don't think it matters at all, but don't take my word for it.
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
Re: Ignition coil.
« Reply #2 on: April 30, 2009, 07:44:29 AM »
Are there any symbols on the new one where the wires are?
Re: Ignition coil.
« Reply #3 on: April 30, 2009, 08:25:19 AM »
The BLACK-with-WHITE is (+), goes to the IGN circuit (power). The other goes to the points.
Magua
Re: Ignition coil.
« Reply #4 on: April 30, 2009, 02:42:00 PM »
Both wires run to the CDI, the green ones appears to split into two after the CDI, one running to the altenator and the other to the ignition. The Yellow passes through the CDI before splitting into three wires and running to the altenator.
So it's black with white (+) to the green?
Re: Ignition coil.
« Reply #5 on: April 30, 2009, 10:30:10 PM »
Green is NORMALY ground which would be the -ve
Re: Ignition coil.
« Reply #6 on: May 01, 2009, 08:32:12 PM »
CDI?  ???
