Author Topic: should i cut my pipes? my brain might pop  (Read 1151 times)
Offline 547
« on: April 28, 2009, 06:46:29 PM »
Having a hard time deciding on what to do with my ugly mufflers. kind of want to cut them off and just have the
straight pipes but in reading related posts i get a lot of information pro and con.
What i gather is that it creates a lean situation so you have to change main jets, you are damaging your engine, loss of power unless your full throttle, loss of back pressure, you have to increase air flow, it's loud and attracts attention, it looks kind of cool, and so on
so what i was wondering is can straight pipes be modified to eliminate all the negative stuff
as long as the modification doesn't involve attaching a muffler to the end of the pipes :)
j-
Offline KB02
Re: should i cut my pipes? my brain might pop
« Reply #1 on: April 29, 2009, 03:53:53 AM »
What do you have for pipes? 4 into 4? 4 into 1? What do you have for a bike? 750? 650? 550? 500? 400?
You have asked a controversial question, as you have found in your research, that really has no straight (no pun intended) answers. One option to think about is that there are baffles available on the market that simply slip into the pipe. Would they work to solve the "problems" and still have all the "benefits" ? Not sure, but it's something to think about.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline 547
« Reply #2 on: April 29, 2009, 07:40:56 AM »
4 into 4 on a 78 cb750. the baffle idea was my original thought, would that solve my problem? how does the length of the pipe come into play?
j-
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #3 on: April 29, 2009, 07:44:13 AM »
Adding baffles to a slip on section would create more backpressure, how much you need would be dependant on your setup.
Offline Alan F.
« Reply #4 on: April 29, 2009, 07:53:20 AM »
You could always sell of your stock pipes and buy the best drag pipes with baffles you can find.... just a thought.
Rich W
« Reply #5 on: April 29, 2009, 07:55:48 AM »
    I have MAC slash out slip ons handy if you want them  . 40$ plus shipping and they're yours . PM me if you're interested .
Rich W
« Reply #6 on: April 29, 2009, 08:04:43 AM »
  I've seen where guys have screwed in washers to a bolt in the pipe to make a form of a baffle .
Offline 547
« Reply #7 on: April 29, 2009, 08:05:31 AM »
the pipes on my bike now aren't stock and i'm sure they aren't worth anything. on a tight budget too.
so i am trying this on the cheap.
j-
Offline Laminar
  • Retsam
« Reply #8 on: April 29, 2009, 08:28:27 AM »
Here are the baffles on the straight pipes that my 550 came with:
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #9 on: April 29, 2009, 08:38:00 AM »
Hahahaha.... Cute.
What I did was punch out the old rusty baffles, weld up the holes in my exhaust and then welded in my own baffles... Sounds MEAN.
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
