Author Topic: Found The Oil Leak  (Read 1417 times)
Offline jx25
Found The Oil Leak
« on: April 29, 2009, 12:04:29 AM »
So I replaced the head gasket on my cb750k8 over the winter months and all the other gaskets above that, but for some reason I didn't bother to flip the heavy motor over and inspect the bottom half.  Got everything back together and noticed that after sitting over night, it had left a pretty good sized oil stain on the cardboard underneath it.  So I tightened up the drain plug and thought problem solved.  Well I was wrong, I started her up and played around with the carbs and noticed the oil stain had grown.  So I got a mirror and discovered a crack.  So I dropped the oil pan and found this.....
Im planning on trying to weld it up but I'm not sure it's gonna work...... :-\
Can't do much on this side
can probably fill this side up
hopefully can get in there and fill this side up
Could this be from overtorqueing the drain plug??
Otherwise CycleX is about an hour north of me and this weekend I'll have to take a ride up there and get a new oil pan
1978 CB750K (slightly modified)
1973 Suzuki GT250
1968 Ducati Monza 250(needs title)
1965 Bultaco 250(needs clutch work)
fuzzybutt
Re: Found The Oil Leak
« Reply #1 on: April 29, 2009, 12:42:38 AM »
do yourself a favor and prevent headaches, get the new pan. either welding or using some kind of epoxy (like jb weld) may  or may not work as i imagine that it might be difficult to get ALL the oil out of the metal around the crack and that would prevent the patch from holding well.
Offline martino1972
  • and still a expert welder,period...
« Reply #2 on: April 29, 2009, 12:51:11 AM »
+1...
Due to the fact that you will have to use the drain plug again to drain oil,I'd would get a different pan...
If it was at a spot where you could leave it alone after the fix,you could JB weld it,but I doubt it would be wise to do it here.... :'(
Marti, I want you to know, I like you an awful lot, but guys have said far less and left wearing their drinks on their shirts.
http://forums.sohc4.net/index.php?topic=36933.0  (my bobber)
« Reply #3 on: April 29, 2009, 04:32:41 AM »
Caused by overtightening on a repeatedly used sealing washer Only real cure is another pan
Offline mystic_1
  • 1970 CB750K
« Reply #4 on: April 29, 2009, 05:25:38 AM »
+2 you'll spend less on a new pan then you will in time and aggravation in trying to fix the old one.
mystic_1
- John Augustus Shedd
Offline ugmold
« Reply #5 on: April 29, 2009, 08:24:30 AM »
I had the same problem on 78 550k, the JB Weld slowed it down, actually worked fine on the side crack, but the face where the drain plug goes leaks. I tried a copper washer, but still leaks.
-ug
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #6 on: April 29, 2009, 08:42:05 AM »
I'd go with the new pan.
But just to be the devil's advocate! You could completely fill the crack on all sides (even over the threads) and retap the hole (through the JB, it says right on the package you can tap the stuff.) On the mating surface for the washer, sand it smooth and flush.
Just saying, JB could work if you did proper surface prep and filled in all sides. Again, I'd go with the new pan.
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
Offline Frankenkit
  • Industrial Strength
« Reply #7 on: April 29, 2009, 09:22:09 AM »
I'm devil's advocate AND a pack-rat.  I'd recommend getting a new one and seeing just how well you can fix the old one. That way, if something bad happens (it'd have to be pretty bad to mess up your sump...) you'll have a spare to slap on until your new order comes in.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline mystic_1
  • 1970 CB750K
« Reply #8 on: April 29, 2009, 09:25:15 AM »
Because of the way the crack is spread out, if you just squeeze JB Weld down into the crack, the hole will end up being larger than it's supposed to be.  If you go this route you need to find a way of clamping the casting so as to squeeze the crack together as much as possible.  This gives you a better bond with the JB anyway.
A good TIG weldor could probably seal that crack in about 10 seconds, then just run a tap through it and you're good to go.  Much better fix.
mystic_1
Offline jx25
« Reply #9 on: May 31, 2009, 11:53:37 PM »
What ended up happening is my father took it to work and clamped the threads then tig welded the crack, retapped the threads, then milled the area the drain plug mates with and made that surface flat.  So far I haven't had any problems.  I have yet to get a non-cracked pan.  I also am using a different gasket than the aluminum ones.
1973 Suzuki GT250
