Author Topic: Quick Motor Cleaning Before Painting Question  (Read 1218 times)
Offline OakBehringer
« on: April 29, 2009, 01:20:22 PM »
Getting ready to paint my engine case (without splitting it, head/block off). I cleaned/degreased it last night. I'm going to brass brush all the loose flaky paint off and rough up the existing paint. What should I wipe it down with right before I paint it?
Thanks!
Adam
1974 350 Four - SOLD
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
Offline robe0531
Re: Quick Motor Cleaning Before Painting Question
« Reply #1 on: April 29, 2009, 01:21:38 PM »
try acetone on a rag or spray with some brake clean it dries pretty fast
1978 cb750k
1968 Honda ca160
« Reply #2 on: April 29, 2009, 01:28:19 PM »
Don't know if I'd use acetone as a cleaner on existing paint.  How about mineral spirits or alcohol? Not likely to lift existing paint.
« Reply #3 on: April 29, 2009, 01:31:13 PM »
I'll have to go pick up either one from the hardware store, would one or the other be better?
Also - dumb question - is that "Isopropanol Rubbing Alcohol"?
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
Offline hymodyne
« Reply #4 on: April 29, 2009, 01:45:10 PM »
if you are not stripping all the way down, acetone might soak into the paint and stay there, marring the finish on the final coats you apply.
Offline kghost
« Reply #5 on: April 29, 2009, 02:08:16 PM »
Acetone is a fast evaporative solvent.
It will...if you dump enough of it on the paint....soften and remove it.
When I paint a case...I use Acetone or MEK on a rag to wipe down the case.
Laquer thinner is another option.
I wouldn't worry about a wipe down with MEK or acetone on a rag leaving any residue behind that will screw up new paint.
Stranger in a strange land
Offline bunghole
« Reply #6 on: April 29, 2009, 02:43:35 PM »
Yes.  Maybe put it in a spray bottle to get in all the nooks and crannies.
'05 HD FLSTCI (Heritage)
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
Offline mcuozzo
  • Bottle in front of me or frontal labotomy?
    • 77 CB750K - needs total rebuild
« Reply #7 on: April 29, 2009, 07:45:53 PM »
My advice would be to get as much of the old paint off as you can.  New paint has a tendency to lift old paint.
Acetone, denatured alcohol or MEK are all good solvents to use before painting.  Most automotive stores have a painting prep spray in the paint section.  It's also fine to use.
Post pictures\type of paint you wind up using!
Matt
« Last Edit: April 29, 2009, 07:47:41 PM by mcuozzo »
