Author Topic: Engine removal?  (Read 2312 times)
rachsrib
Engine removal?
« on: May 01, 2009, 01:22:00 PM »
I think I need a top end rebuild on my cb750 and I think the engine needs to come out to do that but, I dont have one of those fancy engine winches to lift it out.  What are some other safe options for removing the engine if I cant get a hold of one.  A friend told me it would be too heavy just to hand lift it out.
Thanks
Offline Johnny5
    • CB350F build thread
Re: Engine removal?
« Reply #1 on: May 01, 2009, 01:24:17 PM »
You can lay the bike onto its right side and pull the frame up and away from the engine. Most people remove and install it in this fashion. I did just this fall/spring.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline MJL
  • Don't listen to me, I'm no
Re: Engine removal?
« Reply #2 on: May 01, 2009, 01:28:56 PM »
One of the posters here had an engine hoist with a chain and a beam. One end of the beam attaches to the motor, the other end has weights to match the motor. The chain goes in the middle
Offline Bob Wessner
  • "Carbs Suck!"
Re: Engine removal?
« Reply #3 on: May 01, 2009, 01:33:53 PM »
Here's a visual from an earlier thread.
http://forums.sohc4.net/index.php?topic=43173.msg448512#msg448512
Offline Geeto67
  • A grumpy
Re: Engine removal?
« Reply #4 on: May 01, 2009, 01:38:35 PM »
remove all bolts.
tilt to one side.
shake firmly and vigourously until engine falls out.
(it is a little simplified but you get the idea).
If  you have a couple of friends you do not need to tear the bike down to the bare frame. You will need to remove the fuel tank, the side covers, and anything else that might shake loose (pun intended).
Maintenance Matters Most
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
Re: Engine removal?
« Reply #5 on: May 01, 2009, 01:48:12 PM »
1. Remove tank and seat.
2. Remove carbs,exhaust and oil lines.
3. Unplug all electrical connections
4. Remove all engine mounting hardware
5. Place stout milk crate next to bike, on right side.
6. Lay on top of frame
7. Lift and rock motor out of frame, towards the right side, onto milk crate.
8. Installation reverse of removal.
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
rachsrib
Re: Engine removal?
« Reply #6 on: May 01, 2009, 01:58:26 PM »
Thanks I like the idea of laying down and shaking think I can manage that.
Thanks
Offline Johnny5
Re: Engine removal?
« Reply #7 on: May 01, 2009, 02:34:09 PM »
Dont forget to remove the breather cover on top of the valve cover. The engine will come out a lot easier.
1971 CB350
1973 CB350F
Offline mcuozzo
  • Bottle in front of me or frontal labotomy?
    • 77 CB750K - needs total rebuild
Re: Engine removal?
« Reply #8 on: May 01, 2009, 05:46:51 PM »
Just did it last weekend.  Not that bad.
Do not remove all the bolts, you gotta leave the two rear ones in and pull them once you tip the bike.
Make sure you got something on the ground to catch the oil that will come out.
And with two people you can leave a lot on the frame.
Use Jack stands and a jack to help raise the frame while your jiggling the engine around.  Especially if you don't do a full tear down to the frame.  You'll need to take a brake from lifting and we used the jacks stands to avoiding losing the progress we made.
Here's what you hope to have when your done...
« Last Edit: May 02, 2009, 04:18:10 AM by mcuozzo »
Offline B.O.X.N.I.F.E.
  • The Stumped
Re: Engine removal?
« Reply #9 on: May 01, 2009, 10:46:45 PM »
Can you do the 'lay it over' method with the pegs/handlebars still on the bike?
btw... any appx. idea of the engine weight with the top end removed? (mines a 550 though)
1974 CB550
Forever West
Offline mcuozzo
Re: Engine removal?
« Reply #10 on: May 02, 2009, 04:17:09 AM »
boxnife, look at my pics above.  The handlebars are still on.  I removed the pegs though.
