Author Topic: disassembling forks  (Read 2236 times)
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
disassembling forks
« on: October 31, 2005, 09:16:19 PM »
okay, never done forks before. would anybody be willing to walk me through the disassembly procedure for a cb550?
i have the oil drained, tops opened up and springs removed, but i'm unsure of how to remove the seals after removing the circlips. also, is the clymers diagram really out of proportion? according to it, underneath the top fork screw should be locknut at the top of the dampener. looking clear down the fork tube, after removing the spring there's nothing there. i assume that's why the allen screw on the bottom of it just spins without loosening, if i can't undo the locknut.
should i just change the seals and leave them alone otherwise? how the hell do you get the old seals off anyway?  ???
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline Einyodeler
  • Midnight bugs taste best!!!
Re: disassembling forks
« Reply #1 on: October 31, 2005, 09:24:17 PM »
Hey Paul
Check out this link:
http://oldmanhonda.com/MC/Rforks.html
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Offline paulages
  • 1976 cb735
« Reply #2 on: October 31, 2005, 11:59:12 PM »
thanks. that's pretty much what i thought i'm supposed to be doing, but the screw on the bottom to release the damper just turns without doing anything, and the manual refers to this retainer nut on top of the damper which i can't even see.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline hahnda
  • lskdfhs;dljksa;
« Reply #3 on: November 01, 2005, 07:03:26 AM »
Happen to have an impact wrench? That might help. If not you will have to stick something down there to keep it from turning. A broomstick or something similar with a little creative carving in the end can be wedged in there good enough to get most of them out.
Kevin
Kevin
CB750K4 in pieces
CB750K3 with F trim
CB750K7
CB500 Cafe Project
CB750 Cafe
Offline Einyodeler
« Reply #4 on: November 01, 2005, 07:56:18 AM »
I`ve gotten most of mine loose by leaving the springs in and the top cap on and that usually puts enough pressure on the damper to turn the bolt.
Offline scott_cb650
« Reply #5 on: November 01, 2005, 10:56:58 AM »
I just rebuilt my forks this past Sunday, 1979 cb650.
The damper bolt came out quite easily with an impact wrench.
I agree that a rod, or leaving the spring in, should hold it enough for the impact wrench.
The #$%* for me was getting the old seals out.
I didn't have a puller so I had to pry them out with a screwdriver.
Why worry about tomorrow for tomorrow has enough troubles of it's own.
Offline GoatBaSS
  • Could someone find an
  • To weird to live, to rare to die.
« Reply #6 on: November 01, 2005, 01:21:01 PM »
A lengthy dowel of some girth will help stop the rotation, and allow you to remove the allen bolt. If the seals are as bad as my last ones were, the cutting wheel on a dremmel tool and a careful hand and eye as not to marr the grooved chamber. After several other attempts that was the best solution for me. Good luck
Leethal # 3046?
1972 CB750K/900CC Red Headed Dunstall, 1975CB750FSS Gone BNF: 1974CB500T, 1976CB750K X 2
