Author Topic: Bike running too rich?  (Read 4713 times)
Offline 78_SaltLick
  • Honda 1974 550
    • Custom Drum making
« on: October 30, 2005, 08:28:49 AM »
My bike warms up fast, a little too fast (dont even need to use the choke when you start it in the morning, and its warmed up within seconds) and once i ride it around for about 30 minutes, it starts to run bad. Sputters and spits when coming out of first gear. I think its getting too hot, even though the RPM's are where they are suppose to be at an idle. Is this what is called running too rich? How would i correct this? thanks guys.
Gold sparkle is the place you outta be.
Offline Bob Wessner
  • "Carbs Suck!"
Re: Bike running too rich?
« Reply #1 on: October 30, 2005, 09:06:48 AM »
You should start by pulling the plugs and taking a look at their condition and appearance.
« Reply #2 on: October 30, 2005, 09:11:00 AM »
If you are running too rich, the combustion deposits on the spark plugs will be a key indicator.
Remove yours and compare them to:
http://www.dansmc.com/Spark_Plugs/Spark_Plugs_catalog.html
Also note the numbers printed on the spark plug itself, so we know what heat range you have.
A clogged or overly restrictive air filter can also cause a too rich mixture condition.
« Last Edit: October 31, 2005, 08:58:48 AM by TwoTired »
Offline 78_SaltLick
  • Honda 1974 550
« Reply #3 on: October 30, 2005, 09:59:47 AM »
Do you have to buy a special socket to get a motorcycle plug out? I have a car plug socket.
Offline Dennis
« Reply #4 on: October 30, 2005, 10:07:53 AM »
Ya do if it's a SOHC4 (sort of).
Easiest thing,
I'd suggest the plug wrench that is supplied in the OEM tool kit. If you don't have that I've heard that it is still available from Honda.
You can choose your source for that, one of the internet/mail order dealers or your local guy.
eldar
« Reply #5 on: October 31, 2005, 08:14:58 AM »
get a sparkplug socket from sears. It is a deep well and works just fine on my 750. It has the rubber insert as do all sparkplug sockets i have ever seen.
Offline KB02
« Reply #6 on: October 31, 2005, 08:47:13 AM »
Just make sure it's the right size for the plugs. A standard Automotive spark plug socket is too small for the amjority of motorcycle plugs.
And, Yes, it does sound like it might be running a little bit rich. Looking at the plugs would be the best way to tell, though.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Dennis
« Reply #7 on: October 31, 2005, 09:35:49 AM »
If you go to Sears be sure to tell them that you need an 18mm spark plug socket. Take a spare plug with you to be sure you got the correct one. As KB02 says the small (5/8") automotive type is too small.
And the standard 13/16" automotive is too large.
« Last Edit: October 31, 2005, 09:37:35 AM by Dennis »
Offline mrbreeze
  • Not your average
« Reply #8 on: October 31, 2005, 09:52:08 AM »
I second that.It is indeed a deep 18mm socket.
MEMBER # 257
MetalHead550
« Reply #9 on: October 31, 2005, 12:23:05 PM »
18mm as long as its NGK, 5/8 if its champion.  At least thats been my experience.  I think you posted this problem earlier?  If you can start w/out choke when its dead cold then I would say definitly rich, especially w/ your carbs since your choke doesnt pull the throttle some along with the choke like newer model carbs do.  Also sputtering off the line and hesitation at lower throttle positions once its warm indicate overly rich.  If youre lean then the performance issues will usually surface at mabey 3/4 to full throttle.  Read up on pilot screw adjustment.  Yours are actually air screws and meter how much air is alowed in through the idle circuit so turning them out some may take care of the problem.
Offline dusterdude
« Reply #10 on: October 31, 2005, 12:34:09 PM »
the champions im using now are 16 mm
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
MetalHead550
« Reply #11 on: October 31, 2005, 01:12:55 PM »
Really?  well scratch that then.
Offline Dennis
« Reply #12 on: October 31, 2005, 10:31:58 PM »
maybe not?
16 mm = .6299"
5/8" = .6250"
.6299 - .6250 = .0049"
Do you think a 16 mm socket will fit a 5/8" sparkplug?
not trying to pick on you duster, but I never heard of a 16 mm spark plug
MetalHead, I would suspect that you are correct about the Champs being 5/8, but I have no clue what Champion plug is equivalent to D7 and D8. It seems that everyone I've ever heard of using them was complaining about the way they ran.
I always ran champs in my mopars, but I never ran them in my bikes.
Offline dusterdude
« Reply #13 on: November 01, 2005, 06:48:24 AM »
i dont recall,when i put mine in earlier this year im not sure i tried a 5/8 socket.i may have used the 16mm because the ngk plug used the 18mm .i may have to take a whack at the 5/8 and see if it will fit.that would be nice if it does.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline dusterdude
« Reply #14 on: November 01, 2005, 06:51:09 AM »
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline dusterdude
« Reply #15 on: November 01, 2005, 06:52:35 AM »
duh,no its not.damnit i found a plug in the same heat range that had a smaller hex.shoot now i got to look some more.be back later
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline mrbreeze
  • Not your average
« Reply #16 on: November 01, 2005, 10:17:11 AM »
16mm and 5/8 are very close to the same size.Its like 13mm &1/2....14mm&9/16....19mm&3/4.They aren't exactly the same but damn close.
MEMBER # 257
Offline dusterdude
« Reply #17 on: November 01, 2005, 11:29:05 AM »
breeze,champion`s website shows the plug i use to be 16mm-5/8.so i reckon 5/8 will work.i need to try that sometime
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline Einyodeler
  • Midnight bugs taste best!!!
« Reply #18 on: November 01, 2005, 11:43:19 AM »
Duster   get rid of those Champions,they`re resistor plugs.
Get NGK D8EA or Denso X24ES-U
AAArrrrgh,I just became an old-timer.
« Last Edit: November 01, 2005, 11:47:59 AM by Einyodeler »
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Offline dusterdude
« Reply #19 on: November 01, 2005, 12:07:02 PM »
yea,i know.i bought them when i to much trouble trying to get the 18mm socket on the ngks,as soon as i buy a thin wall 18mm socket im going to change them back.i will so tho,the bike runs like a raped ape with the resistor plugs in it.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
eldar
« Reply #20 on: November 01, 2005, 12:09:41 PM »
You been an old timer for years! ;D
Offline dusterdude
« Reply #21 on: November 01, 2005, 12:56:22 PM »
well,no need to get personal. ;D
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline mrbreeze
  • Not your average
« Reply #22 on: November 01, 2005, 01:05:52 PM »
Hey Einyodeler,Thats another thing I meant to bring up in my post.Ditch the Champion plugs! I wouldn't run em in a lawnmower!When I was a kid,I had a little Kawi 120 dirt bike that would foul em out as quick as you put    em in.Never cared for them since then.Bosch are good plugs.NGK's seem to work great in my bike.
MEMBER # 257
Offline mrbreeze
  • Not your average
« Reply #23 on: November 01, 2005, 01:11:17 PM »
Damn! Talk about a runaway post!! This is supposed to be about running rich. ???
MEMBER # 257
