Author Topic: vht paint  (Read 1268 times)
Offline bert96
  • past ride
vht paint
« on: May 07, 2009, 04:03:54 AM »
 Do you think the wrinkle plus from VHT, can withstand the heat from the motor? i would like to paint the valve cover,clutch cover,point cover etc...
What do you think?
http://www.vhtpaint.com/wrinkleplus.html
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline Toxic
Re: vht paint
« Reply #1 on: May 07, 2009, 04:18:41 AM »
go to the link you provided,  they have a forum section.
they are very fast to respond.
ask the experts
Offline TheHun
Re: vht paint
« Reply #2 on: May 07, 2009, 05:31:49 AM »
make sure you put the parts in an oven
1978 Honda CB750-K
CBR F3 Coils
Kerker 4.1 Header w/ turn down
Maxi-Dwell Ignition
Foam Air Filter Pods
Superbike bars
Starter Delete
CARB CLEANING/REBUILD: http://www.wix.com/TheHun/CarbCleaning-Site
Not Running to Running, doing the work yourself= Priceless
Offline 73nancy
Re: vht paint
« Reply #3 on: May 09, 2009, 09:35:49 AM »
wrinkle black i have found will take the heat. the wrinkle paint must be baked in order to get the wrinkle look. you can also use a hairdryer would make it a little easier. i have done wrinkle on automotive valve covers and it holds up great. the wrinkle paint will also come out way better when steamed. we used to put it on top of a industrial parts washer and let the steam flow over it. but ya i wouldnt hesitate to use it on your valve cover. VHT makes some very good products as far as heat resitant paint. good luck
k1 cb750 cafe racer (aka Helter Skelter)
k6 cb750 stock daily rider project
k3 cb750 race bike 911 big bore, alum rods, 13:1, race cam other goodies
Offline bert96
  • past ride
Re: vht paint
« Reply #4 on: May 09, 2009, 10:38:39 AM »
I asked the question on the VHT forum and they told me there was no problem for my covers ???
