Author Topic: 76 CB750 F ignition switch disassembly?  (Read 2159 times)
Offline J.Webster Designs
  • www.JWebsterDesigns.com
« on: May 11, 2009, 06:30:27 PM »
as the topic says.... anyone know how to get this thing apart? it seems to have just stopped working all together. used to have bad conact but just stopped working today.
VISIT OUR WEBSITE!
FOLLOW US ON SOCIAL MEDIA!
Facebook:
www.facebook.com/JWebsterDesigns
Instagram:
www.instagram.com/j.websterdesigns
Offline Alan F.
Re: 76 CB750 F ignition switch disassembly?
« Reply #1 on: May 11, 2009, 07:30:07 PM »
http://forums.sohc4.net/index.php?topic=50083.0
give this thread a read, I guess the rubber cover hides the switch that clips onto the end of the lock cylinder...
The bit about spraying some electrical contact cleaner in there may save you some time too.
Good luck.
Offline Flying J
« Reply #2 on: May 11, 2009, 07:53:00 PM »
i have torn apart my 78F 2 times. Is it the same?
Offline jaknight
  • ....Round Town Ride......
« Reply #3 on: May 11, 2009, 09:22:43 PM »
I Would,
First, mark the matching wires, if you feel you have to, and remove the switch from its frame mounting bracket, wherever it might be...... under the gas tank or on a bracket elsewhere.
Then, take off the rubber covering the back portion of the switch.  Look for small holes; I spray electronic contact cleaner in these holes from as many different directions as possible.  Move the switch into a position allowing the contact cleaner to drain out, bringing with it tons of dirty junk.  Repeat this process several times, a lot of gunk really does come out of there.
This will clean up the electrical contact areas and you may not have to pull the switch apart at all.  Let the contact cleaner dry completely before connecting the wires and trying the switch.  I have done this many times on my switch when I was afraid I would have to take it apart.  I never have had to take it apart......... this cleaning process always works for me........ same switch 35+ years now....... :D :D
~ ~ ~ jaknight ~ ~ ~
"THE PEN IS MIGHTIER THAN THE SWORD........
..........EXCEPT IN A SWORD FIGHT"
"There is nothing new under the sun.........But there are many old things we do not know"
BIBLE ---> Basic Instructions Before Leaving Earth
