Author Topic: Motivation Needed to Fix This  (Read 1587 times)
Offline Accolay
« on: May 07, 2009, 06:07:12 PM »
What else should I do to the engine if I take it apart to fix this? The bolt fell out of the engine. Maybe if they used duct tape it would have stayed in there longer.
What am I getting myself into?
The engine is so small though...
But I'm a novice.
But you want to ride the motorcycle, right?
But you could just buy one of those Harley's you saw today...they come already polished!
But this is a classic!
But you could just get some more electrical tape wrapped around the bolt and nobody would ever notice!
What could possibly go wrong?  :o
Just how integral is this to the operation of the thing? I always thought it looked as if it were leaking oil over there...
1977 CB550F
Offline martino1972
  • and still a expert welder,period...
Re: Motivation Needed to Fix This
« Reply #1 on: May 07, 2009, 06:23:08 PM »
if it ain't leaking oil too bad where the upper and lower cases come together around the area where that bolt broke off,you can plug that bolt hole with some plug from rubber or something....
the correct fix would be to pull the engine out and remove the lower engine case,should be possible without taking the top end off and remove the broken off thread and replace with new bolt....
all depending on what bike/model etc it is......
just that one broken bolt won't make your engine to fall apart...... ;)
Marti, I want you to know, I like you an awful lot, but guys have said far less and left wearing their drinks on their shirts.
http://forums.sohc4.net/index.php?topic=36933.0  (my bobber)
fuzzybutt
« Reply #2 on: May 07, 2009, 06:34:35 PM »
and they also come with 100 + year old technology, vibration , horrible mileage and excessive weight.
Offline Accolay
« Reply #3 on: May 07, 2009, 06:43:48 PM »
Right right right...
1977 CB550F
Since I've got it down this far, I might as well fix it....you think?
But if I play that game I will get myself into trouble ie: "Might as well get that new cam while you're here"
1977 CB550F
Offline Alan F.
« Reply #4 on: May 08, 2009, 06:44:23 AM »
1977 CB550F
Don't forget the payments, poor handling, limitted tire choice, and of course the attitude.  But at least you'll get some respect from the guys at the donut shop in town on Tuesday nights, if it's not too hot out to ride that is...
kabuki
« Reply #5 on: May 08, 2009, 07:21:43 AM »
1977 CB550F
Ha, I'm going through this process right now. I opened up my 550 to fix the oil leak and re-ring the pistons. Ended up with a 600 kit, Webcam, new paint, etc...
« Reply #6 on: May 08, 2009, 08:41:54 AM »
Think I have a solution;
 Lathe turn a sleeve that fits in the bolt hole (against broken end)with very little clearance, leaving enough sticking out to grab with vise-grips. Sleeve should have a 3/16 or 1/8 hole.
Now use a left hand drill bit that is 1/8 or 3/16 inch. Install slleve in hole and hold with vise-grips, then drill in reverse with Left Hand bit.. it will probably come out.
Allen f, I hope you run up against a new Sporster so you can show him whois boss.. :o..  & what do you mean by limited tire choice?
Offline Inkscars
  • grumpiness comparable to an
« Reply #7 on: May 08, 2009, 08:51:21 AM »
Why not helicoil it?
It doesn't appear to be a bolt that's "fighting" against compression.
That's what i would do for a better fix. 20 minutes, 20 bucks tops.
81 Hardly Davisson
« Reply #8 on: May 08, 2009, 09:08:08 AM »
Ever try helicoiling 2 1/2 inches down a hole? If you get it wrong it will hold the cases together.. >:( :o
 I re-read, and ...when I  first posted I thought we were talking broken bolt.. wuups :-[
Offline Inkscars
« Reply #9 on: May 08, 2009, 09:16:46 AM »
Maybe I'm misunderstanding?
Yes I've tried, we helicoil for broken spark plugs. People just can't seem to get the new plugs in the 5.4s out without stripping the threads off or breaking 1 or 2 of them completely off.
Is he not trying to hold two case halfs together? If not you could just tap it and replace the bolt too. Either way it's better than tape.
81 Hardly Davisson
« Reply #10 on: May 08, 2009, 09:26:23 AM »
I think we are talking  2.5 inches downa 5 ..SIXTEENTHS .. :o hole..
Offline Inkscars
« Reply #11 on: May 08, 2009, 11:08:50 AM »
Where's your sense of adventure?
81 Hardly Davisson
Offline martino1972
« Reply #12 on: May 08, 2009, 01:08:22 PM »
2.5 inch seems a bit under average I think.... ::) ::) ::) ::)
Offline Accolay
« Reply #13 on: May 08, 2009, 02:04:17 PM »
Considering the cost for new gaskets etc, and time involved (since I've never taken an engine apart before) I'm going to let this one pass for a while. I'd much rather get it on the road sooner. The engine has lasted this long, So I think it will be fine.
The only thing that concerns me is what was the reason for taking that bolt off in the first place?
1977 CB550F
