Well a common coil replacement is a coil from a cb750 from 1979 on tp 82 or something like that. The same coil is on the cb 900. These are 3 ohm coils so spark will be stronger and may go through points quicker if you still use them. If you use electronic then the performance will be better but you may or may not notice much difference.
The wires are replaceable also.
