Author Topic: Suitable Master Cylinder Replacement???  (Read 2209 times)
Offline odin836
  • Honda CB750 K3 (...in pieces...)
CB750 K3 in pieces.
Re: Suitable Master Cylinder Replacement???
« Reply #1 on: May 09, 2009, 04:52:28 AM »
Nice! I am interested in this answer as well....
cheers
Andy
Offline Jay B
« Reply #2 on: May 09, 2009, 05:43:52 AM »
I have one of those on my 550, though not the chrome version. Works very well, I think a big improvement over stock.
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
Offline Sweep
  • Just remember there are no stupid questions, just some idiot asking them.
« Reply #3 on: May 09, 2009, 06:04:04 AM »
Same.  I also have relocated the brake light switch to used the switch on this unit.
'76 cb750K Wiseco 836|ape crank/head|Carillos|CR29s|Dyna 2k|Kerker
'74 Norton Commando Fastback w/belt and bells
fuzzybutt
« Reply #4 on: May 09, 2009, 06:06:16 AM »
that looks like the one honda used for the dual disc brake twin cam 750's and 900's
Offline andy8190
« Reply #5 on: May 09, 2009, 10:17:11 AM »
i just put this one on my 550 and it seems to be working. Jay b, quick question, how exactly is this lever supposed to feel because i am not sure i have my brakes completely bled right or if its the old hose expanding when i pull the lever because the brake works better when i pump it to stop as opposed to just pull one time
Offline odin836
« Reply #6 on: May 10, 2009, 12:26:18 AM »
So is this overkill for a single disc CB 750?
Stock...
CB750 K3 in pieces.
Offline andy8190
« Reply #7 on: May 10, 2009, 12:33:33 AM »
I don't think it is overkill, if i recall from what i have read, but I think I have read that you have to be lighter on the pressure or it can lead to dangerous braking
also how did you guys connect the brake light switch on the mc, are the connectors specific or can they go either way?
« Last Edit: May 10, 2009, 12:55:41 AM by andy8190 »
Offline 547
« Reply #8 on: May 10, 2009, 05:29:59 AM »
i have one like that on my '75 cb750f with dual front disc. not that pretty tho.
j-
Offline Jay B
« Reply #9 on: May 10, 2009, 06:58:54 AM »
I have the stock brake line on my setup, and I've got a VERY solid feel at the lever. No pumping required. Sounds like you still have a little air in the system somewhere. HTH
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
