Author Topic: Rear Brake Shoe Cam, Felt Washer and a Squeak  (Read 1023 times)
Offline Really?
« on: May 10, 2009, 10:17:23 AM »
Yanno that big cam that goes through the brake hub and the shoes mount to on one end?  Does this get lubed?  If so, with what?
Also, where does that felt washer go?  I only see one.  I saw it on my leg after the shoes came off.
I had a squeak (flippin' loud) back here when the rear brake pedal was perty much fully depressed.  Is the need of some lube there the culprit?
I have deglazed the rear drum but it did not look bad.  The old shoes really did not look worn but have new ones to go in there anyway.  The shoes appeared to be flat and not conical shaped.
« Last Edit: May 10, 2009, 11:12:44 AM by GigaWhiskey »
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Really?
Re: Rear Brake Shoe Pin, Felt Washer and a Squeak
« Reply #1 on: May 10, 2009, 10:50:47 AM »
So I am guessing that the felt washer goes on that cam next to brake lever.  Saw it in the fiche as #4.  Any guesses on the rest of it?
The big brake shoe cam I am referring to is #5 in the fiche.
« Last Edit: May 10, 2009, 11:13:10 AM by GigaWhiskey »
