Author Topic: CB350 TWIN valves  (Read 1323 times)
Offline Chester345
  • will someday be an...
  • 76 CB750F
CB350 TWIN valves
« on: May 11, 2009, 08:12:00 AM »
Does anyone know if the Honda service manual numbers are the best to use for clearances?  I only ask because on my CB750, it runs better with them open wider than suggested.
In .002 and ex .004
Stockish airbox and original exhaust.
Thanks!
Offline Johnny5
    • CB350F build thread
Re: CB350 TWIN valves
« Reply #1 on: May 11, 2009, 08:46:05 AM »
Stockish?
Elaborate.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline Chester345
  • 76 CB750F
« Reply #2 on: May 11, 2009, 08:55:37 AM »
Well, original box and filters, but there isn't much left of the filter material, they are clean though.
Same with exhaust, might be a little more free flowing than stock and such.
I don't mind setting and takin a ride, and repeating the next day, was just curious for other's thoughts.  =)
Offline lordmoonpie
    • Moonpie
« Reply #3 on: May 11, 2009, 01:57:11 PM »
Hmmm - stock camshaft?
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #4 on: May 11, 2009, 02:23:17 PM »
Manufacturers like to keep valve clearances as small as possible, for the simple reason of top end noise. If you ride near redline a bit, though, slightly more clearance is helpful. Causes less wear, and handles the top end a bit better.
Unless you are looking for quietest engine you can have, and don't spend a lot of time stressing the engine, the outside margin of the clearances stated are better, and sometimes, even a little wider is better.
No.
Offline Chester345
  • 76 CB750F
« Reply #5 on: May 12, 2009, 07:42:08 AM »
yeah stock cam, bike gets ridden aggressively, heh.
Appreciate the responses!
