Author Topic: Choke will not stay engaged  (Read 971 times)
Offline texaninseattle
  • lots of protein in my
  • OHH Canada
« on: May 14, 2009, 09:07:49 am »
On my '78 cb550, once I pull up the choke and take my hand off, it falls open again.
Any one else with this problem, or is this normal?
1978 Cb550k(Sold)
emgo pods
mac 4-1
105 mains
stock pilots
needles set 1 step richer than stock
IMS 2 turns out
1982 Suzuki GS850g
Re: Choke will not stay engaged
« Reply #1 on: May 14, 2009, 09:17:15 am »
At the base of the choke knob is a friction adjust.
Offline Soos
« Reply #2 on: May 14, 2009, 09:18:15 am »
.... if thats the entrance to canada, sign me up!
ooh... sorry got hypnotized by your avatar....
NO idea on why your choke drops closed.
.... sorry.
IS the 550 a cable actuated choke, or like the 750, is there a lever on the side of the carbs?
If it is a cable, look for a "tightening" nut to increase the tension on the cable.
I know 650 carb setups have a hidden nut for the choke cable to increase the tension on the line to keep it from falling on it's own.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline edbikerii
    • Gallery
« Reply #3 on: May 14, 2009, 09:24:29 am »
The round section that holds it onto the bracket is knurled so that you can adjust the tension by hand.  Try tightening it.  Of course, that doesn't always work, especially if you have lubed the cable.  So, either get used to holding it up until the bike is warm enough that you can ride it, or go buy a new OEM cable from Honda and don't lube it.
Perhaps it is possible to clean lube off of it with some kind of solvent (kerosene?  brake cleaner?) without destroying it.
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline cb750fbomb
  • is by no means a
  • "No hope? See, that's what gives me guts!"
« Reply #4 on: May 14, 2009, 09:41:09 am »
I can twist mine slightly clock wise and it will stay without using the friction adjust. It will slowly right itself and start falling. s'weird man.
'77 CB750F2
“The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair.”
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: May 14, 2009, 09:45:49 am »
Thanks guys, I have never noticed a knob, but will give it a look when I get home
The knob is often covered in a rubber boot to protect it.
Actually it's more of a knurled ring than a knob, but it sounds funnier that way :D
mystic_1
- John Augustus Shedd
Offline cb750fbomb
  • is by no means a
« Reply #6 on: May 14, 2009, 09:51:13 am »
Mine has a rubber sleeve over it so that the knurls don't knurl your fingers.
'77 CB750F2
