Author Topic: Exhaust gaskets  (Read 1231 times)
Offline cb750fbomb
  • is by no means a
  • "No hope? See, that's what gives me guts!"
Exhaust gaskets
« on: May 16, 2009, 12:21:00 AM »
I just want to verify. Do you have to buy a new set every time you remove the exhaust? From my research I'm getting mixed answers.
'77 CB750F2
“The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair.”
Offline Soos
Re: Exhaust gaskets
« Reply #1 on: May 16, 2009, 12:32:54 AM »
depends on how cheap you are.(or more correctly how broke you are)
I have gone both ways(that sounds wrong)
I am willing to use them 2-3 times without any sealant, and if adding sealant(high temp silicone or whatnot) up to 5 times.
Depends on how much(if any) they leak.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline mystic_1
  • 1970 CB750K
Re: Exhaust gaskets
« Reply #2 on: May 16, 2009, 05:34:24 AM »
Do you HAVE to?  No one has a gun to your head.
Are you SUPPOSED to?  Yes.
Worst thing that happens is an exhaust leak, then you have to drop the pipes and spring for new gaskets.
mystic_1
- John Augustus Shedd
Offline cb750fbomb
  • is by no means a
Re: Exhaust gaskets
« Reply #3 on: May 16, 2009, 05:49:50 AM »
They're not leaking at all as it is, but I was going to pull them off to paint them. I believe they are the original headers, but I know the muffler isn't stock. Those gaskets are pretty cheap, but I just don't want to spent money that doesn't have to be spent. Since this bike has seen 3 owners, including me, I have no idea if the gaskets have been reused.
'77 CB750F2
Offline Alan F.
Re: Exhaust gaskets
« Reply #4 on: May 16, 2009, 07:39:51 AM »
If they don't leak, is there a need to replace them?  I wouldn't, but then again they should never leak with new gaskets.
Offline cb750fbomb
  • is by no means a
Re: Exhaust gaskets
« Reply #5 on: May 16, 2009, 07:55:56 AM »
So, I'll try with the old gaskets and if they leak I'll get new ones. Simple enough. Thanks.
'77 CB750F2
Offline VTCBike750
Re: Exhaust gaskets
« Reply #6 on: August 06, 2011, 07:00:49 PM »
What do you guys think would cause a new (200 miles) gasket to start leaking?
-Adam
1972 CB750 (current project)
http://forums.sohc4.net/index.php?topic=87951.0
Offline trueblue
Re: Exhaust gaskets
« Reply #7 on: August 07, 2011, 01:53:39 AM »
I had a similar problem with my bike and it turned out to be a crack behind the exhaust flange, but it may just be that your pipes need to be retensioned.
1979 CB650Z
Offline VTCBike750
Re: Exhaust gaskets
« Reply #8 on: August 07, 2011, 05:32:31 AM »
Retensioned?
-Adam
Offline trueblue
Re: Exhaust gaskets
« Reply #9 on: August 07, 2011, 05:45:43 AM »
Retensioned?
Yeah check that the bolts that hold them on to the engine are tight
1979 CB650Z
Offline VTCBike750
Re: Exhaust gaskets
« Reply #10 on: August 08, 2011, 04:44:25 AM »
Yup they were tight. Loosened everything, reassembled and now the pipe is loose. Its like theres isnt even a gasket in there. Just waiting on new gaskets.
Anyone ever doubled up on gaskets?
Its a Kerker 4-1.
-Adam
