Author Topic: OEM piston rings two different colors, why?  (Read 9957 times)
Offline B.O.X.N.I.F.E.
  • The Stumped
« on: May 16, 2009, 08:13:03 AM »
I got 4 new sets of Honda OEM piston rings for my '74 550. It's standard bore. One of the rings is regular carbon black, the other is also, but it's light grey around the face of the ring.
They both seem to have the same end gap. I was thinking it might be to keep from mixing them up if they're ever disassembled after use, but that doesn't seem likely. Should I worry about it?
1974 CB550
Forever West
WHALEMAN
Re: OEM piston rings two different colors, why?
« Reply #1 on: May 16, 2009, 08:31:21 AM »
Do you mean all four sets look different or two from each set are different? The top and middle ring ARE different. The light gray you refer to is chrome on the top ring. make sure you have a manual that shows which ring goes on top and which side is UP. Dan
  • The Stumped
« Reply #2 on: May 16, 2009, 08:47:00 AM »
I mean that one ring in each set is different. My manual says to make sure the manufacturing mark is facing up, but I didn't see anything saying the two rings are different.
So the chrome faced ring goes on the top most groove of the piston?
1974 CB550
Forever West
Offline WFO
  • Will work for powerbands
« Reply #3 on: May 16, 2009, 09:46:24 AM »
Yes it goes on the top.
82 cb650 sc nighthawk - 78 kz 650 b
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #4 on: May 16, 2009, 10:24:39 AM »
If you look at the gray band with a magnifying glass, you will see it's actually a bevel cut into the top outside of the #1 ring.  You will also notice there is a faint "R" stamped into the 2 solid rings.  the "R" faces up with the beveled ring in the highest slot.
Read your manual carefully as there are other important assembly details in there.  One tip I can give you is when it comes time to lower the bores over the rings, be VERY gentle.  If you force the bores down you can snap a ring.  Work with the center two pistons first.  Place square-ish shims under the piston aprons to hold them firm and steady.  A wobbly  piston makes the job 10x as hard.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline donny
« Reply #5 on: May 16, 2009, 06:48:25 PM »
good timing..I installed rings on the pistons today, but not into the cylinder.....bass-ackwards I guess....I didn't know which ring went on top so I measured the original rings, the top ring was 1/2 a thou thinner which was not the new chrome ones.  Well, I can change them tomorrow.
  the grey rings had no markings on them, so the bevel on the top is the only way to identify up?
2007 Husqvarna self propelled lawn mower    1976F    1971K    1974K      1990 FXRS-SP
  • The Stumped
« Reply #6 on: May 16, 2009, 09:48:52 PM »
I checked the OEM and Clymer and there was nothing about different rings. Not with the rings either. I guess you just have to know.
1974 CB550
Forever West
« Reply #7 on: May 17, 2009, 05:40:37 AM »
I'm surprised these manuals didn't mention it.  My Haynes manual has a lot of shortcomings, but was pretty explicit about installing rings.  Even when it cam to gap position.  Please do a through search of this site for more details on installation incase my Haynes, and by extension, I am wrong on this.
Hopefully some of the more experienced builders will chime in.
Sure.
Is it hard?
Offline donny
« Reply #8 on: May 17, 2009, 06:48:15 AM »
this throws a wrench into the mix ?
 Quote form Bodi, 05/07/07.......
    {The two similar rings have different profiles. One is basically flat where it will contact the cylinder wall, the other is bevelled slightly. The flat one is the top or compression ring. The bevelled one is the 2nd or scraper ring, the bevel faces so that it scrapes oil downward. The bevel may be hard to see but if you look at the end with a magnifier it should be visible.}
so the flat ring goes on top ?
and the beveled one (chrome) is the second layer?
« Reply #9 on: May 17, 2009, 07:34:47 AM »
Clymer varies from year to year, I have 2 , will try to check, but sure I have seen it in there.
Cut 2 blocks with an open ended slot to hold the pistons up, use 3/4 or 5/8inch thick. Use plywood, alum or plastic then to do the other 2 you either need a thinner set or the first set may work (depending on thickness) It not worth it, without doing that on at least the first 2 pistons.
 I usually use a Popsicle stick, ice cream stick, or Starbux minitonguedpressor, the help guide the rings in.. if my fingers dont work. NOTE, the former was for 1pce oil rings, dont think it will work on 3pce.. :(
« Reply #10 on: May 17, 2009, 10:29:06 AM »
This should help or not. My Honda Service Manual has no info. My Clymers has no info. My Haynes manual for my Acura Legend has no info. My Chilton's manual states "The compression rings are not interchangable. The upper compression ring has beveled edges, while the lower one has a square cross-section".
« Last Edit: May 17, 2009, 10:52:11 AM by Jerry Griffin aka Rxman »
Offline donny
« Reply #11 on: May 17, 2009, 10:30:59 AM »
thanks a bunch..
« Reply #12 on: May 17, 2009, 11:01:24 AM »
I would assume by installing the top ring with the bevel up it would allow the rings to enter the cylinder easier.
Offline donny
« Reply #13 on: May 17, 2009, 01:25:58 PM »
damn if there wasn't a stamp on the chrome rings after all..these old eyes couldn't see it, without a magnifying glass... the other rings had a stamp that was easily read.
 I still don't understand why the new chrome rings measured the same as the old second ring, and vice versa.
thanks again all..... ;D
  • The Stumped
« Reply #14 on: May 17, 2009, 03:41:39 PM »
Jeez, you'd think something like that would be mentioned somewhere. And, if I had to guess, I was going to guess the chrome faced one went in the second groove. So I'm glad I asked!
1974 CB550
Forever West
WHALEMAN
« Reply #15 on: May 17, 2009, 04:06:20 PM »
Just think about the guys who are reading this and thinking,"OH NO". They either know they put the chrome ring on in the middle spot or never checked and have no idea where the chrome one is. I would have to believe there are a lot of bikes running around with them wrong. Dan
« Reply #16 on: May 17, 2009, 04:20:35 PM »
LOL!!... Just got a wonder... LOL!! Ha ha ha... yea... just gota.... wonder.... silly nubies!! LOL... yea... just... gota... <deep breath>  wonder...  :-\
Sure.
Is it hard?
