Author Topic: Please take away my tools, I can't use a torque wrench!  (Read 3388 times)
Offline B.O.X.N.I.F.E.
  • The Stumped
« on: May 21, 2009, 05:54:25 PM »
Call me old school, but I've always used my trusty scale type wrench when I had specific ft. lb requirements on a build. But I thought I'd join the 21'st century and get a click-stop type.
So I get the thing and start torquing, expecting it to do the free spinning, clicky sound thing when I reached the right torque. But it just kept on tightening. I think I heard a slight click somewhere along the way, but I'm not sure. Is it supposed to just click once when you reach the right torque, or start spinning freely? (i expected the latter)
1974 CB550
Forever West
Offline BlackMax
Re: Please take away my tools, I can't use a torque wrench!
« Reply #1 on: May 21, 2009, 05:58:26 PM »
dude, I did the same thing the other day, and was SURE I popped a bolt while tightening down a cam cap.   I was using a 1-click type wrench, but had it in my head that I was using a ratcheting type that wouldn't let me overtighten.  The wrench was about 20" long, so I could strip the aluminum by practically blowing on it.
I don't have an answer for you, but am glad that I'm not the only one to screw up using a wrench recently.
1978 CB750SS, 4-1 Yoshi, Pods, 3-angle valve job, ported chambers, ported intake, 41a cam
Offline Spanner 1
« Reply #2 on: May 21, 2009, 05:59:06 PM »
One click is all you get when it hits the torque setting......not supposed to click it more than once too.....!
Offline my78k
« Reply #3 on: May 21, 2009, 06:05:40 PM »
Thats how mine works! Except I can't usually hear it over the music or hockey game or whatever I have going on when working in the garage...
Dennis
Offline moham
  • .fnord.
« Reply #4 on: May 21, 2009, 06:08:09 PM »
Both Craftsman torque wrenchies I have (3/8 and 1/2 drives) don't even click audibly, at least not to me. Instead when you reach your setting (and you should be slowing when you get close), it just pops out of torque for a sec. If you were bashing away, you could easily keep torqueing. Take it slow and you will feel it pop.
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
  • The Stumped
« Reply #5 on: May 21, 2009, 06:14:54 PM »
I was doing some praying while backing them off, because they were wayyyy over tightened. Thanks guys, next time we'll do Hammers 101.
1974 CB550
Forever West
« Reply #6 on: May 21, 2009, 06:25:52 PM »
I teach torquing to our shop guys. There is a very quiet click sometimes but you should feel it. If you are at the torque setting it should keep doing that as you continue. Yours may be defective.
Offline Alan F.
« Reply #7 on: May 21, 2009, 06:36:10 PM »
Both Craftsman torque wrenches I have (3/8 and 1/2 drives) don't even click audibly, at least not to me. Instead when you reach your setting (and you should be slowing when you get close), it just pops out of torque for a sec. If you were bashing away, you could easily keep torquing. Take it slow and you will feel it pop.
+1 on that, I've made a habit of keeping one hand on the ratchet end and one on the handle while torquing anything, that way I'm sure to feel the detent that the wrench signals the operator with.
When in doubt, practice on something that's not valueable, like a bolt clamped in the bench vise....
Offline new2novas
« Reply #8 on: May 21, 2009, 08:41:24 PM »
depending on the torque sometimes you can't even feel it, i keep an eye on the pivot point and go slow
75 cb750F
Offline Bill Vaughan
« Reply #9 on: May 21, 2009, 08:50:28 PM »
If you want to get a feel for how it should react at the point of reaching the selected torque value, put the drive end in a vise and pull on the wrench until it "clicks".  Do this at a few different settings so you get a sense for how it should feel when attached to a bolt/nut.
Sounds stupid, but it actually helps.
1972 Z50A
1973 ST90
1975 CL360
1971 CB450
1975 CB550
1978 FLH
2003 FLSTS
2006 FLHRSI
Offline tygrant
« Reply #10 on: May 21, 2009, 08:54:08 PM »
or stick with the guage/scale type... its what I use, not fancy but it works
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
MotoMartin
« Reply #11 on: May 21, 2009, 08:56:09 PM »
It seems with the "pop" type torque wrench, the wrench part has to be exactly 90 degrees to the socket otherwise you don't feel the pop. This is possible as there is a bit of slop in the mechanism, which is accentuated by the length of the torque wrench.
If I am working on something delicate (like cam cap bolts) I use the old fashioned pointer type torque wrench where you can visually see how much torque is being applied.
Offline new2novas
« Reply #12 on: May 21, 2009, 08:56:44 PM »
no, not stupid....i was torquing the heads on my motor (small block) on a stand a bunch of years back for the first time using one and didn't notice it clicked and broke a head bolt off, not the end of the world but i did have to buy a new set of bolts just to replace the one....if you were to strip threads out you would have the joys of at the least putting a helicoil in, at worst cracking whatever it is around the bolt or bolt hole and having to replace it
75 cb750F
Offline Sparked
  • Cheaper then therapy
« Reply #13 on: May 21, 2009, 08:58:32 PM »
+1 on placing the other hand on the rachet end of the wrench. I usually put my hand over the rachet end with my thumb on the body of the wrench and even if you can't hear the 'click' you'll feel it for sure.
1972 CB350F
1982 CM450A
1961 Ford Falcon (time for four wheels)
Offline Derby City
« Reply #14 on: May 22, 2009, 06:57:15 PM »
I have a craftsman click-type torque wrench that I bought when I was probably 16 or 17 years old. It makes a noise, and you can feel it when you hit the right torque.  When torquing, I always tighten very slowly.  I used to borrow my buddy's Snap-on set when I did internal motor work.  It worked the same way.
I've been told to back the tension off the wrench (i.e. adjust it back to the lowest torque rating) when not using it.  I may have read that in the instructions when I bought the wrench.  I believe it's supposed to keep the wrench working properly.
1974 CB 550
Offline mikethejeepguy
« Reply #15 on: May 22, 2009, 07:09:30 PM »
+1 on going slowly when torquing. Also make sure that you are using the right torque scale, one time I stripped some bolts when the setting called for inch-pounds and I set it to foot-pounds. Besides that, my torque wrench is pretty loud when it clicks and I can feel it in the shaft as well. Maybe try a different manufacturer? I have heard that it is also bad to keep your wrench preloaded, so I make sure to back mine off to zero before putting it away.
'76 Honda CB550F, Dana-S'd, Uni filtered, HID'd, LED'd, and mildly cafe'd with many plans still.
Offline mystic_1
  • 1970 CB750K
« Reply #16 on: May 22, 2009, 07:32:31 PM »
Correct.  This helps prevent the internal spring from weakening as quickly.
mystic_1
- John Augustus Shedd
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #17 on: May 23, 2009, 03:39:11 AM »
Can you describe this better? You speaking of a beam type torque wrench?
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #18 on: May 23, 2009, 07:03:26 AM »
Pretty sure he means one of these.  Which if you have a nice one, is great (I have a cheaper version).  I also have a couple of the ratchet style ones which I tend to use more these days.
Light audible click but more of a feel thing.  Slow and steady.  I'd hate to have a torque wrench simply let go and start spinning freely when torque was reached - can only imagine the busted knuckles.
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #19 on: May 23, 2009, 07:14:25 AM »
If that's it, yup, it's referred to as a beam design. I have one, hard to go wrong with one, but there are situations where they are not a good fit for the job.
