Author Topic: Question 72 CB350 Twin Engine  (Read 1828 times)
Offline vintagemcycleguy
« on: May 21, 2009, 06:46:42 PM »
I'm tearing down a 350 twin engine to rebuild and I need to know how to get the cam chain off. Do I cut it and replace it or can you remove the cam chain without breaking the it. Thanks.
Offline mark
Re: Question 72 CB350 Twin Engine
« Reply #1 on: May 21, 2009, 09:21:50 PM »
It can come out in 1 piece.
There's a manual here if you don't have one.... http://forums.sohc4.net/index.php?topic=17788.0
Good luck.
F you mark...... F you.
justjosh
« Reply #2 on: May 21, 2009, 09:48:19 PM »
   my name is josh and my # is 916-753-0462. i can walk you thru it.
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #3 on: May 22, 2009, 09:26:21 AM »
It's pretty easy, if I remember correctly. Just unbolt the cam gear from the cam. Then work the cam out of the head. You'll have to turn it this way and that to fit through the mind-tease puzzle holes.
No.
Offline rchrdms
  • Honda CL350 Twin '72
    • Richard F Meese
« Reply #4 on: May 24, 2009, 08:23:26 AM »
Sorry, but I think you have to take off the crank first. I've only gone as far as removing the head and cylinders, though.
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: May 24, 2009, 08:34:11 AM »
Yup, on most (all?) of these CB's, you cannot remove the cam chain without splitting the crankcase.
mystic_1
- John Augustus Shedd
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #6 on: May 24, 2009, 09:46:25 AM »
Crap, I misread, though he was askign how to get just the CAM off, not the chain completely.
No.
Offline lordmoonpie
    • Moonpie
« Reply #7 on: May 25, 2009, 02:56:53 AM »
I gues sit depends on the size of the job - if you're just replacing the chain or taking the barrels off you can do that by splitting the chain and using the chain to pull a wire around the crank. Do your work, leaving the wire in place then use the wire to pull back through a new camchain when doing it all back up. You don't ven need the wire if you have the barrels off, I've replaced many a 350 chain using fingers and one of those little pen magnet things to pull the chain around the crank without splitting the cases.
The wire method is by far the easiest though if you don't want to split the cases...
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline rchrdms
    • Richard F Meese
« Reply #8 on: May 25, 2009, 07:58:09 AM »
If you're just taking the cam off, you can loosen the cam sprocket bolts and slide the cam out through the cam case.
Offline mystic_1
  • 1970 CB750K
« Reply #9 on: May 25, 2009, 08:17:35 AM »
mystic_1
I should have added, "... or cutting the cam chain, which requires a master-link for reinstallation.  Stock chain is endless without a master link."
mystic_1
