Author Topic: 750 f/k  (Read 1719 times)
750 f/k
« on: November 06, 2005, 05:48:00 PM »
Will a 78 750K head go on a 78 750F block (jugs) ??
Offline mick750F
Re: 750 f/k
« Reply #1 on: November 06, 2005, 06:05:50 PM »
   Isn't that what Sean just did?
Mike
Glosta, MA
Re: 750 f/k
« Reply #2 on: November 06, 2005, 06:11:50 PM »
Thats why I ask.  ???
Offline scondon
  • Mmmm......tasty bugs
Re: 750 f/k
« Reply #3 on: November 06, 2005, 07:45:23 PM »
It'll fit fine but you have to machine trenches at the base of the F block to connect the oil returns. F2 head only returns oil down the outer ones(4), the inner ones are blocked off at the base. The K head( and 75-76 F?) return oil down all 8.
Re: 750 f/k
« Reply #4 on: November 06, 2005, 08:11:24 PM »
Sean,
I had heard that you could swap one way but not the other, was'nt sure which was which.
Have only worked on K motor and not had a lot to do on them as it is.
Last week we pulled the donor motor down that we are building next years race motor from .
It looks nice and clean inside, as if oil has never got dirty in it, looks good.
Sam.
Re: 750 f/k
« Reply #5 on: November 07, 2005, 06:29:51 AM »
You could TIG closed the inner head return holes in the early F head/late K head too.
Offline scondon
Re: 750 f/k
« Reply #6 on: November 07, 2005, 07:38:58 AM »
    I considered that when I did my engine but was concerned about oil pooling around valve stem seals at the blocked returns.
