Author Topic: Ok, I am a newbie with the vintage Honda SOHC's, ???? on parts.  (Read 1707 times)
ditchen
« on: November 04, 2005, 02:07:38 PM »
After I got this cb 750 and did all the general tune up, tires and chain, well after putting some time on it I notice an oil leak out of the tach cable where it goes in the valve cover. I am sure there wil be some other things that will urface after it been sitting so long.
I have been looking at the where to buy parts in the faqs but have a  question. Will I be able to order through one of them. Any best reomedation from one to another on getting this seal?  Can the local steeler get one??
What stinks I seen one go on e-bay before I notice my leak last night after yesterdays ride.
Mike L.
Buffo
Re: Ok, I am a newbie with the vintage Honda SOHC's, ???? on parts.
« Reply #1 on: November 04, 2005, 03:53:37 PM »
i have a K8 and I got a new seal for my tack cable from these folks ...1-888-331-5679
Offline mick750F
« Reply #2 on: November 04, 2005, 04:18:14 PM »
   These seals are available from dealers. They're only $2-$4. You might want to order one for a DOHC. They have a little tighter fit. Also, an application of something like Hondabond on the seal helps prevent leaking.
Mike
Glosta, MA
ditchen
« Reply #3 on: November 04, 2005, 06:01:32 PM »
Thanks, will give the above a try. Just hate sheet that leaks anything. BTW, I just noticed the petcock now is seeping a little bit of gas. Thanks again.
Mike L.
Offline 74cb750
« Reply #4 on: November 05, 2005, 09:30:09 AM »
Hey Mike L.
the gastank petcock has a small rubber 4-hole washer. $5.oo at local Honda shop. They tend to dry out
good luck,
michel L.
Laugh at least once a day.
Life  $ucks, then you die.
