Author Topic: spedometer cable screw  (Read 3834 times)
Beakin
« on: May 26, 2009, 06:49:25 PM »
Im talking about the screw that strips really easily,  That connects the cable to the wheel
I didn't even get to strip it, that was already done for me..
sadly its now lost so im having trouble looking for a replacement
using the search function i could only find out "It's a panhead 5mm X 25 mm" any one know the thread size or any replacements from the hardware store that would work?
for a cb750F '77
thanks
« Last Edit: May 26, 2009, 06:59:49 PM by Beakin »
Offline Bob Wessner
  • "Carbs Suck!"
Re: spedometer cable screw
« Reply #1 on: May 26, 2009, 06:53:45 PM »
What model bike? On the 750 the parts list says 5x15 and it is still available from Honda.
Beakin
« Reply #2 on: May 26, 2009, 06:57:57 PM »
yes 750F '77 ill put that in the first post
where is this parts list? can i order from it?
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: May 26, 2009, 07:00:33 PM »
I should specify that the parts list I looked at covered the K0-K2. Can't swear it didn't change after that, but I would try to search a fiche and try ordering from a Honda dealer or Hondapartsdirect or someplace similar.
« Reply #4 on: May 26, 2009, 07:37:34 PM »
Just for fun how did you get it out??  Have two bikes that are stripped before I could get to it(or do it myself!!!!). When I recently changed a front tire on one I had to wrap the speedo cable inside the rim spokes. Did you drill off the head?? and is there enough left to get a grip??
« Last Edit: May 26, 2009, 07:49:26 PM by ekpent »
Beakin
« Reply #5 on: May 26, 2009, 08:23:17 PM »
i tried to make dremel a slice into it for a flat screw driver, which didn't work but with the edge of the cut i could tap it out with a hammer and a flat head
Offline cb750fbomb
  • is by no means a
  • "No hope? See, that's what gives me guts!"
« Reply #6 on: May 26, 2009, 09:10:17 PM »
I just got one at the hardware store the other day.
Home Depot
Machine Screw
Flat - Phillips
5mm x 16 mm
Steel/ Zinc Plated
'77 CB750F2
“The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair.”
Offline tomkimberly
« Reply #7 on: May 26, 2009, 09:26:19 PM »
This tool set works every time: http://www.sears.com/shc/s/p_10153_12605_00952155000P?mv=rr#descriptionAnchor
Tom
Offline Johnie
« Reply #8 on: May 27, 2009, 10:56:11 AM »
You know what works every time for me with that screw...even if it was chewed up...get yourself an impact driver.  You will use it on more than just that screw.  This comes in very handy when removing the stator cover, tranny cover and clutch cover.  When mine was chewed up I used a Dreml to make new grooves and it came out the first time.
« Last Edit: May 27, 2009, 11:00:35 AM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline babyfood1217
  • The only way to drink espresso is as a
  • I miss my baby...
« Reply #9 on: May 27, 2009, 11:16:45 AM »
If you buy from a hardware store, just make sure you get the correct pitch - likely to be 1.25 (so 5M1.25x15)
-Chris
I need help moving my project bike from Wisconsin to Seattle, WA.  Willing to pay well.  Contact if interested.
SOHC member: #438
Project: 1976 CB750K
GSXR forks, Monoshock Rear end, 836 in progress, RC51 pipes, custom frame and everything else.
Offline cb750fbomb
  • is by no means a
« Reply #10 on: May 27, 2009, 01:07:12 PM »
I used one of these: http://www.aldn.com/prograbit/  to extract the screw. Mine was rounded out very badly, but apparently there are cheaper ones out there. I took the old screw to Home Depot and the guy there found a replacement by tracking down a nut to fit it.
'77 CB750F2
Offline markb
  • When I finish my current project I might be a
« Reply #11 on: May 27, 2009, 02:16:10 PM »
Is it the screw that's stripped or the hole?  I've had the threads in the hole break out (not a lot of thread in there) when I tried to remove a stuck screw with an impact driver.  Can't helicoil it either because it will prevent the cable from going in.  But its hard to believe that the screw stripped.
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
« Reply #12 on: May 27, 2009, 04:17:19 PM »
You found someone who actually helped you and came up with a rational solution. I am sure they will be discharged shortly.  ;D ;D ;D ;D ;D
Offline david 750f
  • 1976 CB750F
« Reply #13 on: May 27, 2009, 04:30:27 PM »
Should be a 5mm by 0.8 pitch...16mm in length.
Cheers
1976 CB 750F
« Reply #14 on: May 27, 2009, 04:51:17 PM »
I was afraid to use the impact driver until I read this post. For years I have been removing the cable from the speedo when removing the front wheel.
  • I miss my baby...
« Reply #15 on: May 27, 2009, 05:30:24 PM »
Cheers
Well now I feel like a horses a** ;D
SOHC member: #438
Offline Johnie
« Reply #16 on: May 27, 2009, 07:29:11 PM »
Works everytime for me Bobby.  I do not think it can be put in that hard that the impact driver can not get it out.  I have not had one rusted in place yet.
Oshkosh, WI  USA
Offline tomkimberly
« Reply #17 on: May 27, 2009, 08:57:42 PM »
[/quote]
The last two bikes I worked on my impact driver just rounded out the screw head until there was nothing to grip on. Ended up drilling both of them out. Did I mention I hate PO's?
Tom
Beakin
« Reply #18 on: May 27, 2009, 09:29:40 PM »
thanks a lot guys, ill make a trip out to home depot tomorrow and let you know how it goes
« Reply #19 on: May 27, 2009, 09:55:40 PM »
Use the impact driver but dont hit too hard as i have seen the speedo gearbox broken by that as its not supported
Offline Johnie
« Reply #20 on: May 28, 2009, 05:26:28 AM »
Tom
[/quote]
Before I used the impact driver I used a Dremel to cut deeper grooves into the screw for the impact driver to get a better bite.  Just be sure your driver is set to turn in the correct direction.
Oshkosh, WI  USA
apoji187
« Reply #21 on: May 28, 2009, 08:40:39 AM »
+1
I broke my original speedo gearbox with an impact driver. Luckily replacements are available, but it was one of those "shoulda" moments.
« Reply #22 on: May 28, 2009, 02:32:52 PM »
That was my fear Brian. How would one properly support it, and is that support on or off the bike?
Beakin
« Reply #23 on: May 31, 2009, 10:02:54 PM »
Thanks guys the 5X16mm machine screw from home depot is working great
« Reply #24 on: June 01, 2009, 03:49:27 AM »
If screw is realy bad remove speedo drive box and place back of screw on a wooden block before attacking the screw
